Question about GE Monogram Side by Side Refrigerator
We hsve a recent leak in the chilled drinking
We have a recent leak in the chilled drinking water line somewhere on the refrig side if our 2003 Monograsm ZFSB23DND SS. Icemaker works, thre is a delay when getting drinking water, and after it flows there is water dripping from the underside of the fridge side.
I pulled from wall and removed back plate covering motor and the leak is not visible from the back. It is visible by peeking under the kickplate in the front.
Csn i empty the whole thing, tilt it over, and see whatever i need to replace? Sounds like a cracked plastic hose or connector issue between the chilled reservoir in the fridge and the plastic tube that comes out and heads for the freezer door.
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Posted on Apr 25, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
  • 1796 Answers
SOURCE: noisie fan in the freezer.
Hi!!
Did you turned the unit ON besides of just pluggin it into the wall???
When you plug unit into wall outlet you still need to turn unit ON manually.
Setting either or both controls to OFF stops cooling in both the freezer and fresh food compartments, but does not shut off electrical power to the refrigerator.
The temperature controls are preset in the factory at 37°F for the fresh food compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended settings.
The temperature controls can display both the SET temperature as well as the actual temperature in the fresh food and freezer compartments. The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Keep me posted!!
Posted on Aug 21, 2010
Ice maker set up
it takes a couple hours for ice and not as long for water to chill .
Feb 09, 2015 | Samsung 26 cu. ft. Side by Side...
No ICE or Chilled water
Colin,
The water line is fine (what about water inside that line). Please check the source of the water line, I am sure when the previous used it they might have shut the water valve somewhere. Check your basement for that small valve etc.
Feb 27, 2014 | Whirlpool Refrigerators
The hose inside the frig.is very long,I think maybe that is why I don't have good preasure in the water dispenser,can I cut it? and would it help
If you have a side by side the coiled tube in the back of the fresh food compartment is the resevior for the chilled water it goes there and gets chilled before being dispensed through the in door dispenser. LEAVE IT IN PLACE AND DO NOT CUT IT,
Instead if you havent already done so replaceyour water filter,if equipped with one it will be in the front grill below the freezer door, OR if you have checked it or it doesnt have one pull the refrig out and disconnect the water pressure coming into ref. from house plumbing, if it only trickles its restricted somewhere in the line and seek out why that is .
Gene
Aug 13, 2011 | Whirlpool Refrigerators
I would really like some help with hooking up the ice maker. The line is there bit no ice or cold water, water is warm. Can you hep?
The routing of the water line is
house water supply into built i filter on refrig,
out of the filter into the water inlet valve on back of ref,
larger dimeter tube from valve into water tank behind crispers in ref,chills water,out to door,
smaller diameter tube from valve into icemaker
seeing where you said all lines are in place i believe the issue is that the refrig isn't properly cooling? the first to affected when not cooling is icemaker/water dispenser
Hope this helps
Gene
Jul 29, 2011 | Hotpoint HSS25GFP Side by Side...
Drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
May 29, 2010 | GE GSS20IEP Side by Side Refrigerator
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
I would like to know something.I have a big plastic corel in the back of the crisper pan and I do not know where it go.I have a plastic tube which go from the water valve inlet to the drinking water line...
The coil of plastic tubing behind the crisper is your chilled water reservoir for the water dispenser. They use a coil instead of a tank because it chills the water more quickly and ensures good turnover of the water with less chance of stagnation.
Jul 27, 2008 | Frigidaire Refrigerators
GE Monogram Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
