I have a Maytag Atlantis model MAV8551AWW top load washer. When it starts to agitate or spin it makes a loud squeling sound and you can smell a burnt smell. Is there an ajustment for the belt?
  • 2 more comments
  • mexirican18 May 11, 2010
    The belt looks good. Should the motor be able to move side to side in the slotted holes with the belt on?
    The belt looks good. Whats the purpose of the slotted holes on the sides of the motor on the base plate. Should the motor be able to move side to side in the slotted holes when the belt is on?
    So the motor will move side to side in the slotted holes with the belt on? How do I put more tesion on the belt? The belt looks good
    I have a maytag atlantis washer model mav8551aww. It squeels when its on through the whole cycle. The tube has trouble spinning. Like the belt is loose. But the belt looks good. Should the motor be able to slide back and forth in the slotted holes with the belt on.
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16010061.pdf
http://www.servicematters.com/maytag_library/docs/16022808.pdf
OK above please find a couple of service manuals, this is what the engineers use to troubleshoot and repair these units, below is washer DIY troubleshooting site. This is either the clutch, or motor problem, but please work through the troubleshooting and hopefully you can effect a repair.
http://www.washerhelp.co.uk/diy-repair-safety.html
Posted on May 11, 2010
    President:
  • 949 Answers
The motor is mounted on a plate with spring but it does have slotted holes in the mount. With the front cover removed you can see the motor on the left front corner. Loosen the screws and slide the motor snug with the belt on, while holding the motor tighten the screws.
If the belt looks warn or shiny you many need to replace it also. Tip the machine up slightly to view it, it will roll off the pulleys with ease.
  • Philip May 11, 2010
    The motor itself should be solid on the motor mount. The mount will move side to side on the base of the machine
    If your belt looks good and not shiny the squeak may not be coming from there.
    The motor tension is rarely ever in need of adjustment.
    If may be coming from the snubber, that is located where the base of the washer connects to the tub support. See the image below (parts 22 and 23). Try moving the tub around in the base and see if you hear that sqeak, if so you can add a drop of oil down there but not much at all. The right fix it to replace it if it gets noisy from wear
I have a Maytag Atlantis MAV8551AWW purchased in 2005. Recently the during the spin cycle it began to make a loud noise while spinning, in addition, it seems to vibrate quite a lot almost to the point
switch the machine off at the power.pull the machine out. at the top of machine at the back you will see two screws,remove slide the top of machine forward or back until it relises it will come,once the top is removed you will see a large cement type brick??yes you heard me wright<?take a good look a this brick if its broke that what you need but sometimes the anchor points com loose ,,,,but you will see the problem at the top of the machine .if this is not the problem come back to me,adrian....
Jan 22, 2015 | Maytag Atlantis MAV8551 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV8551aww, loud grinding noise during spin cycle.
Yes. Junk It. Problems that cannot be fixed and customer service stinks
Oct 24, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
