Question about Kenmore 43142 Front Load Washer
Error message 5d on kenmore he2 fron load
The machine will make a loud noise on the rinse cycle and then will show a message 5d
  • mamarenie Dec 17, 2008
    i am having the same prob. a s d code then my washer stops i tried vinegar and using hot water alone.. and today i tried a wash again it said sd then f 21 flashed!
  • 172 Answers
Hi mankin1,
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck. Mike Anderson mca0824@aol.com
Posted on May 02, 2008
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load HE will not drain. gives error code of 5d
the error is SD. it means Suds. you use too much soap or the wrong kind. Must be HE. Remove top and find the pressure switch. Its white with a clear hose going to it. Unplug the hose and blow through it. This will clear suds from the line and you should hear bubbling in the tub. Re install hose and top. Run machine EMPTY with about a quarter cup of bleach and a little soap to rinse out tub and pump. Do this on a WHITE cycle. After this, it should be fine.
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load error 5d
Nov 12, 2008 | Washing Machines
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
774 people viewed this question
Sal De
fordexpert
Robert Rankin
