Question about Whirlpool LER8648L Electric Dryer
No hot air
My dryer turns on and is blower air but the air is not even warm. I have a whirlpool LER8648. Anyone had this problem? What was the fix?
  • Whirlpool Master
  • 43,501 Answers
Hi, If you have a gas dryerno hot air - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dno hot air - 2_bing.gifrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 13, 2010
My extra large capacity Whirlpool dryer does not dry in one cycle. Even if I only put a small load it takes at least 3 cycles to dry
There maybe an air flow issue. With the dryer on check the air flow from the exterior location of your home. There should be a good flow of warm/hot air coming out. If not the inside of the dryer may be full of lint.
Feb 21, 2011 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
Whirlpool Imperial dryer cyclic thermostate
there is a easyer way to check this put unit back together...put or had on back were vent blows hot exhaust air out...you should feel it get very very hot...then start to cool down..were you could put your had on the vent....if not replaced fixed tsat....please call if need more help..mike..843-384-8474...
Apr 03, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
My dryer is not getting hot its not drying clothes even when they have been in for 3 hours
Is dryer getting warm at all. If it is your heater and t-stats are fine. Make sure it is exhausting to uotside properly. Turn dryer on and go to outside exhaust. you should leel air coming thru pretty good. If low air flow pull dryer from wall, disconnect hose at wall and using leaf blower blow the exhaust out to the outside. Impotant thing to remember is blow from behind dryer at the wall to the ouside. Not outside in. Also, electric works better than gas blower due to exhaust fumes caused by gas leaf blowers.
Jan 27, 2010 | Hoover Dryers
Dryer not drying well
Most of the time when a dryer does not do well in drying it isn't getting the airflow it needs to get the moisture out. Heat alone will not dry things. If you can reach your outside dryer vent outlet, turn your dryer on and see if you are getting a good amount of warm air. You can also try the same at the back of your dryer by unhooking the hose. If there is a noticeable difference, your vent system may need to be cleaned. Dryers put out a LOT of air, it is low pressure, but high volume. If you are not getting much out of your dryer, chances are the lint is clogging up most likely before the blower motor.
Also another possibility is that you have the airflow and limited heat. Check the airflow first after you have run it on high heat for about 1 minute, if you do not feel warm/hot air coming out, you may have a problem with a high limit fuse (temp fuse) or a thermostat that isn't working.
That's all I can come up with on the limited information.
Oct 25, 2009 | Whirlpool LER4634J Electric Dryer
MY DRYER IS NOT RELEASING THE AIR OUTSIDE AND MY DRYER IS GETTING SUPPER HOT ON TOP
squished vent hose behind dryer, then clogged vent, then dirty lint filter, then lint built up inside dryer because of vent issue, after fixing vent issue, remove lint from inside blower area filter area etc.
Oct 25, 2009 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool dryer model LGN2000PWO. It
you have an air flow problem. plugged lint screen, dryer vent partially or totally plugged with lint. dryer sheet stuck to the back wall iside the dryer. outside vent cap plugged or not opening. collapsed dryer vent or vent with too sharp of bends in it. and worse case scenario the dryer blower wheel too full of lint. this is provided the thermostats that the tech put in were of the correct heat range and limit.
Oct 17, 2009 | Whirlpool Dryers
Whirlpool LER8648L Electric Dryer Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
