Question about Maytag Neptune FAV6800AW Top Load Washer
Washer turns on, motor runs, tug does not turn. Belts good
  • 526 Answers
Which model TL do you have? FAV6800A or FAV9800A?
What are the first two digits of you Serial Number you can find that on the back right side of the console as you face the machine it will be numbers in the range of 10,11,12 thru to 17.
Looks like you have the front cover off. If you put the washer in Spin Only cycle with the washer top raised slightly what action do you see?
Do the tumblers rotate in the Spin Only Cycle?
Is there any belt squeal from the motor driving the Clutch Pulley in a Spin Only Cycle?
Can you rotate the Wash Basket CCW with slight resistance? It should rotate CCW with one finger.
Let me know if you want to try to DIY the repair……Rich
Posted on May 11, 2010
  • Maytag Master
  • 12,061 Answers
Www.servicematters.com/maytag_library/docs/16022808.pdf
There is a service manual, use this to troubleshoot and hopefully repair your washer.
Washing drum will not agitate
Dear Sir/madam,
First check the Lid switch, motor and belts.
With all that you check, this would be the next thought, this is rightunder the tub AGITATOR, Remove the LOCK SCREW and you should see it.
http://www.partselect.com/xq/aspx/Inventory.65335/qx/PartDetail.htm?SourceCode=1
Parts break down
http://www.partselect.com/ModelFrames.aspx?ModelID=103581&ModelNum=LAT8234AAE&mfgModelNum=&ManufactureID=1&Selected=35576&Position=6&mfg=Maytag&Type=&Mark=6
thanks
good luck
Aug 07, 2008 | Maytag SAV3710AWW Washer
Mower is the Swisher ZT 2660 runs great. Blades slow then stop during cutting, I changed belts (drive & deck). Last year you advised it maybe the electric clutch. Question is that a do it yourself...
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
May 01, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Smells like belt is burning in 1st load of laundry. smells hot
The belt or belts transfers power from the motor to the transmission and pump. If the belt fails, the washer will be unable to pump out the water in the drum nor will it be able to spin the drum or operate the agitator. The washer will sound as if something is running (the motor) but everything under the lid will remain motionless.
The belt is a replaceable part. If you smelled the belt burning, chances are it has been stretched or is missing chunks and is damaged. It should be replaced after unplugging the washer and disconnecting the supply hoses. Next, determine that nothing is jammed and everything moves as it should. This would be the pump and the transmission. You'll probably have to turn the washer on its side to access the belts. Be prepared to mop up water that will spill once laid on its side. If pump or transmission is jammed, the motor will probably burn up the new belt, too. Make sure nothing is preventing the agitator from working - this could be clothing wrapped around / under the agitator. It is possible that something has become lodged in the pump housing. You won't be able to see it - but you should be able to turn the pump - if either of these won't turn, you'll need to get them turning freely before you can expect the motor to spin the belts.
I hope this helps and good luck! Please rat emy reply. Thank you.
Apr 05, 2011 | Admiral Washing Machines
Washer will not agitate, you can hold the shaft still and the motor still turns. The coupling looked in good shape. Whats up?
Hi, if your washer doesn't agitate, check these:
  • Lid switch
  • Motor coupler
  • Belts
  • Clutch
  • Drive motor
  • Drive pulleys
  • Transmission
  • Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems: Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all. The transmission may have a worn or broken gear, or some other internal problem. If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Nov 27, 2010 | Washing Machines
Washer wont agitate on ultra cycle
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Feb 06, 2010 | Kenmore Washing Machines
Agitotor not spinning during wash cycle M/N: LSR8244EQ1 Machine less than 10yrs. old, good shape
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 02, 2010 | Whirlpool Washing Machines
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Washer runs but wont adgitate
Jan 01, 2010 | KitchenAid KAWS850L Top Load Washer
My washer will not spin or agitate clothes it is a cabrio and just started to day will it pumps water in and out but will not spin or agitate.
Most washing machines work with just one motor... it runs clockwise to run the transmission as an agitator and counterclockwise to run the pump and to turn the whole drum to spin dry.  The belts often look loose but are fine.   Check that the belts are on... if they are then the motor may not be running in reverse.  if that is the case then you need to diagnose whether the motor is the problem or the controller.  Check the centrifugal switch in the motor too.
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune FAV6800AW Top Load Washer Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
