Question about Whirlpool Inglis IP4400 Washer
My washer just stopped working after it finished a load of laundry. The dryer is just fine, the outlets are still working and it isn't leaking. It just died out of nowhere.
  • Whirlpool Master
  • 12,061 Answers
Http://appliancejunk.com/forums/index.php?topic=2931.0
Ok go to that website above and get a service manual, although not exactly like yours, all washers are similar,and the troubleshooting procedures still apply no matter what model. http://www.washerhelp.co.uk/diy-repair-safety.html
Posted on May 11, 2010
I have a Kenmore Laundry Center.I washed 1 load then started another wash load. The washer filled with water completed the wash cycle and did not spin. I cannot get the washer to start again by...
Be sure there is power is coming from wall outlet and be sure breaker hasn't tripped. Also if there is a loose connection where cord was installed to unit, there may be a burnt wire.
Sep 11, 2017 | Washing Machines
Washer filled with water then stopped working, still full of water. Drier works just fine. Happened durring an electrical short in my house, but the fuse that was blown was not linked to the same part of...
You state you had a short in the home. Since the washer is on 110V system, you can try a different outlet and see if the machine works. Although you state that it isn't on the same part of the panel as the washer/dryer, and the dryer works, the dryer is on a different breaker, and it may indeed have had some effect on the panel that hooks to the washer. Try my first option, and let me know how you make out. I believe you'll find that to be the trouble
Joe
Sep 07, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Washer will not turn on. i have checked outlet
Some machines have a limiting fuse in the wiring. this has possibly blown. replace it and retry. Normally the fuse is found in the panel on top. It will be in a fuse cartridge. If when you do find it and replace it,and it blows again, your board will be the problem. .
Sep 21, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool LTG6234DQ Stopped Now Won't do anything
a sink stopper will not damage your unit its to big,,it cant get though your wash basket...check your outlet,,or use another out rated 15 amps or more..
Nov 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Inglis IP4400 Washer Logo
263 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
