Question about Easy Flo EF1400 Central System Vacuum
My easy flo built in system wont turn on when the
My easy flo built in vacuum system wont turn on when the hose is plugged into the wall outlets, yet the main canister in garage will turn on manually. Any idea what is wrong and how to fix it ?
    Sniper:
  • 52 Answers
If there is a switch on your hose, it may be broken.
Your system powers on from the inlets via two low voltage wires that run from the inlets to the switch/relay at the power unit. Each inlet has 2 spring loaded pins attached to the low voltage wires. In the photo below you should see these pins at the bottom of the opening, just above the door hinge. The receptacle at the top of the inlet in this photo supplies 110 volts to power your power nozzle. Not all inlets have this option, but if yours does, exercise extreme caution. Your hose must have a completely metal end or if it is a plastic end, it must have a metal band in order to short the 2 low voltage wires together to trigger the switch.
You can manually short the two low voltage pins together by using a metal pipe or needle nose pliers, just touch both pins at the same time. CAUTION: stay away from the 110 volt receptacle if present.
If your system powers on with this manual method then it would seem that the problem is in your hose.
If your system does not power on; your low voltage wires may be disconnected from the power unit or disconnected somewhere else . It's also possible that you have a bad circuit/controller board in the power unit.
Posted on May 22, 2010
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
Our Easy-Flo built in vacuum system will not turn off, even when the hose is disconnected. We have to turn it off manually. Could it be a short in one of the wall outlets causing this?
Some models have an on/off switch on the power unit itself. This switch is used to turn your power unit on when you are right at the machine.
If there is no switch on the power unit, unplug your power unit from the wall socket, look for two low voltage wires coming out of the power unit. These two low voltage wires are usually either attached with terminals or are tied to two wires coming out with plastic screw on wire caps. Disconnect the 2 low voltage wires. Plug your power unit back in. If the power unit does not come back on then yes, the problem is most likely a short in the outlet wiring. If the power unit still comes on with the 2 low voltage wires unattached, then the problem is in the internal circuitry of the power unit, usually a relay or some units have a circuit board with relay, circuit breaker and other components on it. The relay or circuit board will have to be replaced.
It's a little difficult to check for a short if you have multiple outlets, but if you've recently done some renovations you might start checking in that area.
May 19, 2010 | Easy Flo EF1400 Central System Vacuum
I have an easy flo vacuum model # 199C and it won't shut off. It started out as an intermitent problem but now will not shut off when the hose is unplugged, nor when the off/on switch on the main unit is...
Remove the low voltage wires (top left) if the vac unit still runs the problem is with vacuum
if the Vac stops running then there is problem with the low voltage wires in the home possible short some where in the system Chech the inlet doors first. Easy Flo vacuums have a lifetime warranty call 1800 easy Flo.
Feb 13, 2010 | Easy Flo EF1500 Vacuum
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
Easy Flo Central vacuum will still work at about
Yes you can easily test for a clog, and a crack for that matter.
to test for a clog push a dry garden hose through the entire system until it comes out at the other end.
to test for a crack, Disconnect the pipe that comes from the house to the central vac unit. Turn on the unit and put your hand over the opening directly at the central vac unit.(Using the utility inlet at the unit will not accomplish the same thing.)
  • Step 2 If your suction is good, then reconnect the tubing and turn on the switch at the unit. If there is no switch, plug your central vacuum hose into one of your inlets to start the system. Then have someone completely seal the hose with their hand. While the unit is running go to the exhaust. With everything closed you should feel almost nothing coming from the exhaust. If you feel very little exhaust, then you do not have a leak
  • Jun 06, 2009 | Easy Flo EF2300 Central System Vacuum
    Model 116.1260
    Need the complete model #, 116.1260*****. I assume this is a built-in system? Yes you have to plug the hose into the wall outlet, and there usually is a switch on the hose handle to turn it on.
    Jul 23, 2008 | Vacuums
    I have any easy-flo built-in vacuum. I recently had the bearings on the motor, top and bottom replaced. I put the vacuum back together and it mow has low suction power. There is plenty of suction on the...
    There is either a blockage or a pipe is open somewhere. You should check the system at the wall valve without the hose to determine if the pipes are blocked or if perhaps the hose is plugged. If one of the wall valves is damaged or open, this will affect the whole system. Some times, there is painting or renovations taking place in the home and a valve has been removed during the work. I have seen this many times. All valves must be in place and closed for the system to function properly. I have also seen garage valves held open by storage boxes, etc. and they are overlooked because they don't get used often and in some cases, the home owner doesn't even know they are there.
    If you turn the machine on with the switch on the side of the unit, observe the sound of the machine. If the motor races, then the pipes are closed (no breaks). If the motor runs normally, you have an opening somewhere. The same thing applies to the valves. If you turn the machine on and the motor races even when a valve is opened, then you have a blockage, but if the motor doesn't change when a valve is opened, then the pipes are compromised.
    I hope this helps. Let me know.
    Feb 18, 2008 | Vacuums
    Easy Flo EF1400 Central System Vacuum Logo
    203 people viewed this question
    Top Easy Flo Vacuums Experts
    JoeVacs
    Are you an Easy Flo Vacuum Expert? Answer questions, earn points and help others
