Question about Pioneer NS-DV88 System
Plexglass can loose
Hey in my box the screws can loose that holds the plexeglass to the box and it now virbrates can i screw a couple new holes or will it make it sound different
Ja, dat kan
Posted on Jul 25, 2008
SOURCE:
Need the hooks and bolts for little angels swinging crib
Sorry, best I can tell you is to hold the pieces together and measure the holes both diameter and length. Then go to either your big box or local hardware store and buy the screws and nuts and washers. Of course the screws need to be longer than the holes and purchase Stop nuts (nyloc nuts) so they don't come loose by themselves.
Nov 08, 2016 | Baby Gear
Tip
How to quick fix Stripped Sheet Metal Holes Without a Sweat!!!
Have you ever been there??? Been where you ask??? Well been at the end of a job with just one screw left to be installed as a last and final touch to a door skin or some other type of trim molding and found the hole was stripped out and the screw you have to put into the hole is "swimming" in the hole due to it being oversized? you try using a self tapper screw and same results too loose not dependable to secure anything appreciable.
Ok I have a quick and easy savior for all you guys out there in
mechanicsville.
Go into your tool box or small parts/screw cabinet and pull out a cotter pin and that same self tapping screw that is a bit smaller then the stripped out hole, bend the cotter pin out straight and form an "L" shape with it...insert the small L angle shape into the hole... then with a little finess work the self tapping screw into the hole at the same time allowing the screw to be buffered off the cotter pin on the side of the hole, thread the screw into the hole holding the cotter pin steady and "Walla" screw goes down tighter then it ever fit before, if need be get your dykes and clip off the excess cotter pin material left outside the hole.
Hope this works for you.
Happy Motoring!!
on Jul 17, 2010 | Chevrolet El Camino Cars & Trucks
I have an Amy crib T4589 serial 100510320254 that I pulled from storage but can not find hardware. "Nuts and bolts ect" where can I find these. I do not want to buy a new crib if I do not have to.
Nov 07, 2016 | Baby Gear
How to tighten the fridge door handle?
usually the door handle has a couple screws which are more than likely a torque screw but they holes will be covered by a sml pc of plastic covering the screw holes, so u have to remove the plastic pry it out. else ur door may be held by screws located on the inner side of the door
Mar 09, 2015 | Refrigerators
Fridgitaire affinity speed control board fix
Are you looking for the easiest way to do the job, if so, you need to get behind the machine, unplug unit, and get the rear access panel off the unit. Pull the belt off, then using a 5/16", drop the 3-4 screws that hold the motor on, then slide it a little out of the way. Speed control board sits in that white box right next to motor. There is one screw that holds it to the side of unit, and two screws that hold a "L" brace to the board and the floor. Watch where the wiring goes to the different points, then slide the box towards the front and lift to remove. Get board in better position, remove wiring, then put new board in. WARNING the insides and sides of the access hole area's are RAZOR sharp. Use good gloves or severe caution while working inside and near the edges. You can very easily loose a finger or cut yourself very badly. Good Luck!!!
Nov 10, 2013 | Frigidaire Washing Machines
How do u change a house hold light switch on a wall
Turn off power.
Unscrew cover plate.
Unscrew both screws holding switch into wall box.
Pull switch outward to stretch wires.
Take photos so you can reconstruct wiring if necessary.
Note color of each screw.
Green is for ground wire.
There are many different kinds of switches.
Single pole switch has two wires plus ground, and both screws will be same brass color, plus green ground screw.
3-way switch has 3 wires plus ground, and one screw will be different color than other two screws, plus green ground screw.
Remove wires from switch.
If wires are attached into holes on back of switch, notice there is small slot next to each hole.
Insert small screwdriver or metal nail file into slot while pulling on wire. This takes 3 hands, and then wire will come out of hole.
Replace each wire onto new switch, matching the old switch, tighten screws very tight, and then put switch back into box.
When pushing wires back into box, you want to keep the wires folded behind the switch as much as possible.
Wires are not harmed when scrunched back into box.
Put switch cover over switch so no possible spark can exit box.
Turn power ON, and try the switch.
http://waterheatertimer.org/How-to-wire-switches.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 17, 2012 | Electrical Supplies
Persistently loose handle on a 20+yr old 9' fry pan
What has happened is the threaded hole the screw goes into had 'stripped out'. The best option is to fill the threaded hole with epoxy, and put the screw back in, tightening it well and letting the epoxy cure. The only alternative is to thread the hole to a larger size, and use a larger screw.
Feb 04, 2010 | Faberware Farberware FSU236 12-36 Cup Urn...
Evenflo exersaucer with animals and a jeep which plays music. How do you change the batteries in the jeep?
It's a little tricky and you'll end up ruining a couple of hte stickers. This is what you'll need to do -
1. Pry the latches loose under the top that hold the jeep in place
2. Unscrew the 4 screws that hold the jeep to the base
3. 2 of the wheels have screws - use a small screwdriver to remove these
4. The window stickers on the same side as the wheel screws cover 2 more screw holes - you'll need to feel for these and poke holes through the stickers to get to the screws.
5. Once you remove all these 4 screws, the jeep should come apart in 2 halves. Dont exert too much pressure while separating them.
6.The inner assembly (purple with gorilla) slides out of the body of the truck. The base of this assembly has 3 batteries that you'll need to pry out and replace.
Sep 19, 2009 | Evenflo Exersaucer Triple Fun Active...
The screw that holds the handle to the top of the canister came completely loose. How do I get to it to reattach?
Buy a epoxy cement and fill the hole with it, then drill a hole a little smaller than the screw, and finally insert screw.
Apr 15, 2009 | Vacuums
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
Pioneer NS-DV88 System Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
