Question about Plumbing
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few hours.Discovered pump works again by pressing restart button, pump failure light was showing.A few hours later the water is not being delivered to house. The time between failure varies. Any ideas
A number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
Posted on Sep 01, 2010
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
Rheem 50 gallon powerdirect vent waterheater keeps cycling
Take note of the barometric pressure when this happens.
Feb 10, 2014 | Rheem Water Heaters
Onga js120. Wont hold pressure
I assume the pump runs when switched on until a preset pressure is reached in the outlet when it cuts off, remaining on standby until the pressure falls due to a demand for water when it automatically restarts.
To achieve that automatic function there must be a pressure switch in the outlet side of the pump and that or the associated circuitry is where the fault must be as the pump seems to run ok when reset is pressed.
If it is modern it is likely electronics are involved and it would seem more likely those are at fault than a faulty pressure switch which could be expected to remain faulty all the time.
Another possibility is the motor is overheating due to a fault or due to the duty cycle being exceeded and the safety cut-out must be manually reset.
Jun 26, 2017 | Northern Tool 12 Room Purple Martin House
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
Our house is on well water. For several months now, the water, whether hot or cold, will suddenly stop flowing if there is more-than-average demand, such as a bath, washing clothes, or leaving the hose on....
Chances are that the problem is not in your well pump.
He is what you need to do.
Turn the power off to your well pump.
Drain all of the pressure (water) from your system.
Find the pressure switch by your tank that turns the well pump on and off. Usually it is on the tank tee right where the pipe comes out of your tank.
Unhook the wires from the presure switch, taking time to label them so you know exactly where to put them back again.
carefully turn the pressure switch off of the pipe nipple.
Turn the pipe nipple out of the tee.
Clean all of the crude out of the bottom of the pressure switch and the nipple.
This crude is what is causing the delayed reaction in the pump.
Reassemble everything as it was and repower the pump.
You should be good to go now.
If not, then turn off the power again.
Turn the nut on the tallest center screw of the pressure switch down about 1 turn. This will make the pump kick on slitghly sooner, but only do this after checking for **** in the pipe nipple.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 03, 2009 | Moen M3887 Chrome Single Function Hand...
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Plumbing Logo
555 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
