Question about Lexmark X5650 All-in-One InkJet Printer
My lexmark x5650 won't print my envelopes; computer says printer is not configured, what do i do. I have it configured on my computer as envelope with proper size, also have envelope loaded as depicted on printer
SOURCE: Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Posted on Jun 02, 2007
Rain041304
  • 63 Answers
SOURCE: printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
Posted on Feb 15, 2008
SOURCE: hp c5280 all in one
Configure paper size in printer properties. Link to HP instructions
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00654323
Worked for me.
Posted on Sep 21, 2009
Roop1980
  • 228 Answers
SOURCE: Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Posted on Oct 01, 2009
Testimonial: "Thank you. I was on the phone with Lexmark a whole hour last night and they couldn't fix it. This corrected the problem immediately! You are a Wiz"
SOURCE: LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Posted on Mar 01, 2010
WHERE DO I INSERT AN ENVELOPE ON MY X6170 LEXMARK COMPUTER.
Follow these guidelines when loading envelopes on your model:
  • The print side of the envelopes faces you.
  • The envelopes are loaded vertically against the right side of the paper support.
  • The stamp location is in the upper left corner.
  • The paper guide rests against the left edge of the envelopes.
  • You choose to print the envelope with Landscape orientation.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned on the envelope.
Aug 10, 2011 | Lexmark X6170 All-In-One InkJet Printer
How do I print envelope with address?
This has to be done through an application like Microsoft Word. For instance on Office 2007 you would select the Mailings tab then click on Envelopes to specify the address etc. In previous versions you would have had to click on the Tools menu then Letters and Mailings then Envelopes and Labels. Once you've got all the information you want printed on the envelope Place the envelope in the printer in the exact configuration shown on the printer. Should have a feed on the side, look for the envelope symbol. Print and you'll be good to go. (:
Dec 21, 2009 | Lexmark Optra S 2455 Laser Printer
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Printer printing blank evelopes ....everything else prints ok. Lexmark printer Z705
Check your setup in your envelope printing software, make sure it's set for the size envelope you're using, it might be printing in the air next to the envelope.
Sep 30, 2009 | Lexmark Z705 Inkjet Printer
How do i print envelopes
Hello!
Printing envelopes can depend on your computer and the program you're using as well as the printer.
Go into a program on your computer that let's you write and print documents (for instance Microsoft Word).
Look around for an "Envelopes" option. In MS Word, in the bar at the top, go to "Tools", "Letters and Mailings" then "Envelopes and Labels".
Enter the required addresses and look at the "Feed" window at the bottom right to see which direction to put the envelopes in the printer.
Now look for a slot somewhere on the front of the printer, or maybe a place on the top or back that has a picture of an envelope on it. If you don't see anything, refer to your documentation to see where the envelope slot is.
Once everything is in place, click the "Print" button in your software on your computer.
That's all there is to it! If you don't have MS Word, look around on your computer for another word processing program. Most computers come with a simple word processor at least.
Aug 08, 2009 | Lexmark X2500 All-In-One Printer
My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
May 17, 2009 | Lexmark X2600 InkJet Printer
Lexmark x7170 won't print on envelopes
j'ai acheter un imprimante lexmarkz515 il n'as pas de cd driver avec
Mar 11, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
248 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
