Question about Adobe Photoshop 7.0 for PC
Where can i download a free software for drawing valve ( tube) circuit diagrams, please?
I need to draw circuit diagrams for tube (Valve) amplifiers. where can i find a free software which will let me do this, please?
  • Anonymous Mar 18, 2014
    The square and circle work but not the squiggly pencil line I can pull up the draw ribbon but it doesnt renew I turned off the program and turned it back on and it still doesnt work
  • 818 Answers
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
I printed out the KF24 pictoral diagram and had to draw a ladder diagram for our HVAC training course in order to troubleshoot the system in the lab. In trying to rectify the Evaporator Defrost heater...
first try putting controls in series with loads. Remember, loads consume power and switches pass power. Start here. If I had a copy of your drawings, I'd be in a better position to address your situation.
Oct 04, 2010 | Beverage-Air Beverage Air KF24-IAS 20.7...
Egr valve
Below is a link for instructions for the removal and installation of the EGR valve along with a diagram. Best of luck.
Greg
97 Buick EGR
Nov 04, 2009 | 1997 Buick LeSabre
Where is the EGR valve on 1986 Dodge Ram D50 pickup 2.0cc 4 cyl
if there pipes or tubes on top of your exhaust manifold that is where your EGR valve should be. if you want diagrams or text to help fix this problem i suggest the book from Chilton. they tend to explain thing pretty well.
Oct 01, 2009 | 1986 Dodge Ram 50
2000 sl1 saturn ODB Codes
using an ohmmeter, you may be able to find the proper specs by googling "proper resistance for egr on 2000 saturn sl1"
Sep 24, 2009 | 2000 Saturn SL
Code P1401
P1401 DPF EGR Sensor Circuit High Input
Possible Causes
DPF EGR signal circuit open, or sensor ground circuit open
DPF EGR signal shorted to VREF or to VPWR
DPF EGR sensor is damaged or has failed
PCM has failed
Most likely a bad DPFE sensor. Fords are notorious for this.
Jun 08, 2009 | 2000 Ford Taurus
The icemaker overfills and the water keeps running and runs out of the fridge onto the floor
Hi, If the ice maker is overflowing, you will need to change the inlet valve. The inlet valve should only draw water when 120V is sent to the solenoid to open it. The inlet valve is located in back and has the water supply tube attached to it.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 05, 2009 | Amana ASB 2623 Side by Side Refrigerator
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Adobe Photoshop 7.0 for PC Logo
164 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
