Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Ice maker not working, water not going in tray.
I have a Kenmore side by side fridge only 2 yrs old, bought 1/30/2006. Model number 106.56542400. It stopped making ice one day. I unplugged the whloe fridge for a day thinking the water line was frozen but this did not help. The slide ice maker shut off switch is blinking red when in the on position. Would the selnoid be bad?
Water is working in drinking supply in door.
Any ideas on what is wrong?
Thanks,
Rodney
  • kenbb Apr 03, 2008
    Alread changed solenoid and still having the problem
  • cvggirl Apr 23, 2008
    Changed the filter and the ice maker stopped working. Help
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Posted on Sep 30, 2010
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Ice maker tray not filling with water.
Changed the filter, now it works fine. I'd still like to find a way to bypass the filter. My fridge is only 2 yrs. old, but I'm sure it will have plenty of life left after these filters become unavailable.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice-maker problem
it will respond better if you fill it with scotch
Apr 16, 2017 | Refrigerators
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Refrigerators Logo
547 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
