JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Posted on Mar 28, 2008
Convergence Problem I have mostly red shadows. After reading all the posting I believe I have a convergence proble and am trying to replace part number stk392-110. I'm not an electronic guru but how do I separate the part from the circuit board? Any lay person instructions I can get would be very helpful
Anonymous
Level 1:
  • Contributor 58 Answers
  • Posted on Apr 02, 2008
Anonymous
Contributor
Level 1:
Answers
58
Questions
0
Helped
50781
Points
95
You do have to take them off of the circuit board but.... unless you are good at soldering and desoldering I would leave this to the pro's, also on JVC's the resistors feeding the convergence IC's can be bad and will cause the new ic's you put in to immediatly fail. But if you do decide to do this repair I have a hint for you. Use STK392-150, this is the same part rated at a higher wattage so it will last longer. You can also request your servicer to upgrade them also. Hope this helps.
I am getting red shadows. the converge mutiple
Convergence is dead.Must replaced 2 convergence ICS.U know how to solders?Tries these Websites Tv repair World.com,Tvrepairkits.com for convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Shadow on my tv
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Convergence red is out of wack
  • Screen looks 3D
0667c5f.pngSOLUTION
2helpful
2answers
Red ghost image or shadow
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
rate me
1helpful
2answers
Red shadow on TV Screen Hitachi HDTV
Your convergence is bad. You need to have convergence amplifiers changed.
Red shadow on tv
If this is a projection tv a shadow usually indicates bad convergence. If you cannot adjust convergence from customer menu have a professional replace convergence amplifiers and reconverge
PT-53wx53g Convergence issue?
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Picture seems to be losing its sharpness and colors bleed
  • Screen looks 3D
2answers
Red sideways hourglass
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Convergence problem
does it cast red shadows on the picuture.. red shadows around letters. might be the red convergence or could be the read yoke has come loose
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
