Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer won't start, but dryer works fine? it is a LSE7806ACE
Washer won't start, but dryer works fine???
  • mlhutsell May 19, 2010
    I posted the model number and the serial number for my stack washer/dryer and 'still' haven't heard back as to what can be done. PLEASE let me know. The washer won't start, but the dryer works just fine. #LSE7806ACE (MODEL),19842408AA (SERIAL#)I have been without my washer for nearly two weeks waiting for an answer...thanks so much! Marna
    President:
  • 949 Answers
I understand your washer is not starting but your dryer works fine. If it is not doing anything at all (no water, no motor) then the problem is either the fuse or the lid switch.
The replacement fuse comes complete with the lid switch, it is located in back right corner just under the washer top.
Posted on May 19, 2010
  • Philip May 19, 2010
    The part number for the lid switch assembly is 12001514 and cost about $55.00
  • 619 Answers
Without the model number this is just a guess but some of the maytag stacks have a fuse for the washer. Remove the 2 screws at the bottom of the front panel for the washer and look along the left front side where the water level switch is and you may see a fuse there. If there is one this fuse is probably blown.
Posted on May 16, 2010
  • mlhutsell May 16, 2010
    Thank you for your input, however, I did post the model nUMber when I wrote. It is LSE7806ACE and the serial number is 19842408AA. Would this make a difference in your suggestion? I will check out the fuse theory, too..
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
Maytag stacked washer dryer lse7806ace
Take the belt off the transmission pulley and see if you can turn it by hand. It will agitate on direction and spin when you turn it the other direction.
Put the timer to spin with the belt off and see if the motor will run. There may be a problem in the start switch on the motor letting it start in one direction but not in the reverse direction.
Special tools are required to remove the transmission and brake assembelies. You also want to make sure there is nothing sticking through the holes in the basket causing it to lock up such as a nail or screw that may have been left in a pocket.
Post back with what you find.
Thanks/Mike
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
287 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
