Question about Hand Tools
Homelite trimlite 25cc with a curved shaft not rotating
I have a Homelite trimlite 25cc with a curved shaft. Model#UT20763 the shaft isn't rotating. I need a repair manual that shows exploded views on how to repair this model.
One that has the parts list would nicely help.
Any suggestions would be greatly appreciated.
  • 10,865 Answers
Hello. Go to the Sears Direct website. Enter your model number and you will see the parts diagram exploded, and the parts list. You can also order from there. J.
Posted on Jun 07, 2010
Homelite trimlite engine runs but head does not spin
Sounds like the inner flex shaft has broken, slacken the tube up at the engine and pull the tube and shaft assemly away, pull the inner shaft out and inspect
Apr 14, 2012 | Homelite Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
I have a homelite trimlite trimmer model UT20006 can you tell me which way the connecting rod goes by the part number on bottom rod bearing?
Check the piston itself. The piston skirt is "cutaway" on one side to clear the counterweights of the crankshaft. If it is installed the other way, the engine won't rotate completely as the weights will contact the longer skirt of the piston.
Sep 28, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a UT20760 25cc Homelite Trimlite and I would like proper instruction on how to start the engine. Instruction on engine say to press fuel bulb 8 times, but I am not at all sure what position the...
Pull the cord with the lever in position 1, when it tries to run, put it in position2 and pull the cord again. Once it starts running, wait 30 seconds and put it in position 3. Operate in position 3 and hit the stop button when you are done.
Mar 25, 2010 | Homelite Garden
Where do I get a replacement screw for the muffler. Homelite Trimlite Model UT20760.
you can take your trimlite in to your local hardware store and match the screw right there in the store or go on line to homelite dealer to order. hope was some help
Jul 11, 2009 | Garden
Need part number s for the entire head assembly of the Homelite Trimlite UT20721" or manual and diagram
Hello daniel_s_kmi:
If I Understand you, you are Looking for the Part Number for the Complete String Head.
If this is Correct, then the Part Number is DA3001A.
>>You can View a Breakdown of this Unit at this Site Addy; http://www.homelite.com/service_support and Select Order Parts. Now Select "Click to Launch Homelite Catalog". Now Enter the Model Numbers (UT-20721) and Click Search. Now Double Click on the Model in the Results Area. Now you can View the Breakdowns for this Unit. Select the "Shaft-Spool and String-Grass Deflector" File. The Complete String Head is # 17 in the Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Hand Tools Logo
66 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
