Have Modem need to reset password - Computers & Internet
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    a password for a modem? that's unusual..what kind of modem?
    Sergeant:
  • 313 Answers
If you don't have any special settings (port forwarding, ect) just set the modem back to factory defaults by go to or look in the back or bottom *depending on the brand of modem* is a tiny hole - you will need a straighted paper clip (or a cake tester) to push and hold **while modem is on and plugged in** for about 30-60 seconds. THat should put the modem back to factory defaults, that will be the factory user name and password that comes with the modem. For example Linksys is always admin (user name) and admin (password).
Hope this helps.
Posted on Mar 28, 2008
How to access your wifi password with 2wire homeportal 1000hw
If you have the setup menu login password you can view (and change) the wireless connection password in the modem setup menu. You'll need an ethernet cable to connect directly to the modem if you can't get to it wirelessly. With the ethernet cable you bypass the need for the wireless password but you will still need to get into the configuration menu, which usually has a password too. After you connect the ethernet cable, open a browser window and enter 192.168.1.1 in the address field and press enter. This is the same web address field you would use if you were typing www.google.com. That 192. address should take you to the modem setup menu. If a password is required it will prompt you to enter the password. If you don't know the password you'll have to reset the modem and start over. (yes, there is typically an actual reset button although many of them are hard to find) After a reset there is usually not a password requirement. Make sure you set all passwords again if you do a reset - want to be sure no one else can get into your router once you are finished.
Sep 19, 2010 | 2wire HomePortal 1000HW DSL Modem and...
Modem not working
You need to hard reset your modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
You need to access the gui or firmware of your modem. If it ask for username and password. This is the time you need to contact your ISP. They will help you to configure the modem. Once they provided you the username and password ofr your modem. Write it down so you will have a copy and in case it happen again you know what to do. Username and password for the modem is different from the username and password for your internet. You also need to enter the username and password for the internet so you can use the internet. If you get a red light for the internet, that means the username and password is incorrect.
If this didnt work. You need to replace your modem.
Jul 02, 2010 | D-Link (DCM-202) Modem
A user name and password
You need to hard reset the modem first. By doing that, look at the back of the modem then look for red button. Get a pen or something pointed that will fit on the red button. Press the reset button of 30 seconds then you will see that the power light will change to orange light. If every light is already disable. You can access the firmware of your modem. username: admin
password: password
the you can configure your modem now.
May 23, 2010 | Westell Wirespeed LiteLine 6100...
Red power light
Apr 09, 2010 | Westell Wirespeed LiteLine 6100...
My comcast modem's internet connection just died a while ago the only light that is on is the power light, and i have rebooted the modem already. how can i fix this?
Apr 05, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Problem with gateway modem.Power light is red wireless light is green,Dsl and Ethernet lights are not on.I have turned everything off and back on.I have disconnected everything and put it back.Nothing...
You need to hard reset the modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
Mar 07, 2010 | 2wire (1000-000057-000) Modem
D-Link DIR-615 wireless modem, unknown password
You need to connect the modem to your computer via the cat-5 cable.
To reset the router, locate the reset button (hole) on the rear of the unit. With the router power on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait for 30 seconds to access the router. The default address is 192.168.0.1 when logging in, the username is "admin" and leave the password box empty.
If you need the manual, you can download it at:
http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
Please rate this solution. Thanks.
Feb 22, 2010 | Computers & Internet
Power light red
Feb 16, 2010 | 2wire (1000-000057-000) Modem
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Password
To remove all the settings of the used modem router, most modem has a reset button and need a paper clip end to press it. If you want to reset the modem to factory default, most likely you:
  1. having power on the modem, press and hold the reset button for at least 10 seconds (or until lights on front starts blinking)
  2. this is most common practise in programming the modem chips.
If that doesn't do, try:
  1. unplug power cord of the modem
  2. press and hold the reset button
  3. plug in the power cord
  4. wait for about 5 seconds then release reset button
If still not able to reset it to factory default, ring the manufacturer's Tech support and get them to help you "reset the modem to factory default".
Apr 11, 2009 | Actiontec GT704WG Wireless Router...
Computers & Internet Logo
David Payne
David Payne
