Question about Coleman Powermate Powermate 5000W Generator
I have a old Coleman powermate Model PC 54 5000 I have no AC Power. I have checked the rotor and stator for continuity in the windings, no problem. I have tried exciting the brushes, got a spark, but still no po AC. I tested for continuity in the rotor by testing from the shaft, to the rings, again no problem. What about the condenser, or diodes? How do you checks these?
    Scholar:
  • 142 Answers
How did you put exciting voltage to brushes? Plus to plus, minus to minus or no mater?
The condenser can be checked by a capacitance meter or an Ohm meter.
Diodes also by a diode test with a multimeter. Reverse should be infinity, forward 0.5 - 0.7 V.
Posted on Jun 08, 2010
I have a coleman powermate maxa 5000 generator model pm0525312 that needs a rotor assembly replacement. The rotor is not passing a continuity test. The rotor is 5.0 kw rf5 model 0049621.
This shows the rotor as obsolete and I'm guessing the stator would be too. Stators are in the $200-300 price range. Probably better to just buy an new generator. Jack's Small Engine shows some stators but not your P#.
Powermate PM0525312 Generator Parts
https://www.jackssmallengines.com/Products/POWERMATE/Rotors-and-Stators
Sep 30, 2017 | Electrical Supplies
Coleman Powermate 6750
You will need to check the resisitance of the stator and rotor windings, and also each rotor/ring to ground (IE rotor shaft) All tests to ground should be 0 M ohms, stators vary but typically around 1ohm or so, and rotors approx 20-30ohms
Nov 20, 2013 | Coleman Powermate Proforce 6,000 Watt 12...
The 220 outlet is only putting out power on one side
What brand of generator and KW? If you onlyone leg of the 22V it us not likely to be the voltage regulator aor rotor. Check to make sure that the voltage is checked right off the stator leads, where they feed the circuit breaker, and not on the load side of the circuit breaker, If you only have 120V on one of the 240V lines at that point, it is the stator winding. Renee advancd-power-technologies.com
Nov 02, 2013 | Coleman Powermate Powermate 5000W...
What is the stator
The stator is the outside part of the generator with the windings. The rotor is the part that turns inside the stator.
Robert
May 11, 2012 | Coleman Powermate Powermate 5000W...
Coleman powermate generator has no output. have changed diodes, capacitor and brushes. i have 12 volts across the brushes but no output at the receptacles. coleman powermate 0545005 5000w
Disconnect the leads going to the brushes, and check for continuity (resistance) of the field winding. You should be able to measure *something* on the order of a few ohms. If you have resistance, then check each brush contact to the shaft that the field winding is on. There should not be any resistance at all, if there is, you have a shorted field winding and will need to be replaced.
Check the resistance of the stator winding next, make sure that nothing is connected to the generator, disconnect the stator wires if you are able (label them!). Check for resistance between the leads (2 wires for a 2 pole, 4 wires for a 4 pole). If there is no resistance, then the stator is open, and will need to be replaced. Also check for resistance from each wire to the frame of the alternator, there should not be any resistance here (indicating a shorted stator). If there is, then you have a shorted stator, and will need to have it replaced.
Replacement is likely to be impractical, probably cheaper to buy another generator with the same engine and keep the old engine as a spare. Still, contact an automotive starter / alternator shop for prices.
Feb 07, 2011 | Electrical Supplies
Checked capacitor, diodes and circuit breakers and all check out ok. Still no output voltage. Excited with 12 volts across brushes. Still no output voltage. Took the head off and check field windings which...
Make sure it is not the brush set.
There must be continuity from one slip ring to another.
If not, but rotor doesn't look burnt - check points where rotor wire is soldered to slip rings, or clear contact point on each side of wire and check continuity there, past slip rings and brushes. Big chance that wire came loose from slip ring.
Had such problem on my Champiion 3500
evern if burnt - rotor is easy to rewind at home, unlike stator.
Unless your model is Inverter type - there is AVR module.
But, unless your rotor has continuity - don't bother going further.
Jan 13, 2010 | Coleman Powermate Powermate 5000W...
Older Coleman 3500 Watt generator, sitting for over 2 years. engine starts and runs normally, but no power generated.
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
Jan 05, 2010 | Coleman Powermate Powermate 5000W...
Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Aug 16, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5500 watt output unbalanced
Get on their website and get the wiring diagrams. They should also have the resistances of the windings. Checking these resistances, may indicate a stator problem. Give the model number and it will be easier to help.
Jul 29, 2009 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Mar 23, 2009 | Coleman Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
699 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
