Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer spin cycle
Mine makes a clicking sound - suspect an off balance load that I did not catch - is there a reset button or anything or am I doomed for a new machine?
THanks
    Sergeant:
  • 351 Answers
No check the drive coupling between the motor and gearcase,is there any plastic/rubber bits on the floor .also check the brake assy you have to remove the gearcase to do this.
Posted on Mar 28, 2008
SOURCE:
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool duet makes loud noises(Hummm) during spin ( drain) cycle. Any idea what would cause that? Unit seems to function properly. Could it be out of balance?
You will need to clean the catch out that is located in front of the pump. Sounds just like it is full of lint or has something clogging it restricting the water from draining. This is where the humming comes from. If you take the bottom panel off. You can see the catch. Just open and clean out.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub gets off balance during spin cycle
also,shorten front legs,lean washer forward,and reset back legs.level.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    AWM 8163 Whirlpool washing machine
    hi there,
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
    during the spin, the load of clothes may have become unbalanced. Stop the washer and
    redistribute the clothes, then re-start it. Repeat these steps if necessary.
    Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
    Washer makes loud thumping after finished spin cycle
    I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
    Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    76 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
