Question about Bosch 24 in. SHU43 Built-in Dishwasher
Ran for 12 hours before we shut it off?
Turned the dishwasher on after supper and when we came downstairs the next morning it was still running on wash or rinse cycle (making noise), the dishes were all wet
  • 306 Answers
Probably the timer has failed. It is stuck but can't be fixed. Not difficult to replace.
Posted on May 11, 2010
It kept running, clicking to try and shut off but couldn't. Freezer thawed. I shut off for a while, vacuumed coils, turned back on and it ran fine for three days, working perfectly. Next morning repeat...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
One of 2 Lennox AC units not working well.
check the filters if it needs cleaning....or check the refrigerant level if it is below normal
Aug 11, 2009 | Heating & Cooling
Dishwasher tripping all sockets
Your unit has a short in it...could be anywhere. You really need to use a VOM to troubleshoot the problem
Apr 29, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My sons 1990 626 ran great. I change the oil and reconnected the speedometer cable that had vibrated loose. took it for a drive to make sure I didn't have any oil leaks. It ran for about 5 minutes and just...
we'll assume fuel is good..leaving spark and air..and management of systems(computer /sensors)...so the speedo cable was disconnected? try taking it loose again , test drive and report back please
Nov 20, 2008 | Mazda 626 Cars & Trucks
There seems to be an electrical fault in my dishwasher. It is a slimline candy dishwasher purchased only three years ago. Everytime I try to start it all the electricity goes in the downstairs of my house....
Hello sue by rne..
If your fuse blows when you are running the dishwasher alone, I would agree that your dishwasher may have a problem however becuse you stated that it works sometimes..I am more apt to believe that when you run the dishwasher in conjunction with other equipment on that same fuse that the overload condition happens because you've added that dishwasher to an already loaded circuit. The problem is that when you say that you turned off all other electrical equipment downstairs, you may or may not have shut off everything on the circuit the fuse feeds. If there is a way to isolate the dishwasher onto a seperate power feed that you know is not over-loaded then that would prove that the diwshwasher is ok or not.. If you aren't an electrician or trained in this, I suggest you get someone in that is. My initial impression of the problem from your description suggests that your dishwasher is OK but you are somehow overloading the circuit when other things are on.. Hope that helps...
Sep 29, 2008 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
226 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
