Question about Maytag MGR5750 Gas Kitchen Range
Gas oven will not light/turn on. Cook top works fine
  • Maytag Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 11, 2010
Gas does not come on for oven to light
im assuming that your cook top works fine and that the broil is working fine. You need to replace the oven ignitor. The automatic gas valve is equipped with a sensor that opens the valve. if the ignitor doesn't heat up the sensor, then the valve will not open. replacing your ignitor should solve the problem.
Feb 06, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not come on however broiler, cook top, lights, and control panel etc. all work fine.
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 22, 2011 | Siemens HG2416UC Gas Kitchen Range
My pilot light comes on< but the oven will not
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Clock and lights work but cook top and oven do
The clock and the lights run off of 120 volts and the heating elements work off of 240 volts.
It would be safe to say that one leg of the power is missing. Try turning the circuit breaker off then back on fully.
If this does not solve the problem then you will need an electrician to check the plug behind the range or the 'L2' in the range.
Apr 26, 2010 | Bosch HGS435UC Gas Kitchen Range
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana Ovens
My oven doesn't light
you should check your fuses located in the top of your stove
Feb 16, 2008 | GE JGBP24 Gas Kitchen Range
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Maytag MGR5750 Gas Kitchen Range Logo
126 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
