Question about Car Audio & Video
Car radio locked up when battery was disconnected. was given an acura integra from my son had to have the starter changed and they unhooked the battery, called my son who now lives in california he does not have the code or the owners manual
  • Car Audio & ... Master
  • 4,869 Answers
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
Posted on May 11, 2010
My key is locked in the off position and when Im able to start it, when I press in the clutch the starter engages and the radio and heat dosent work. Do I have a bad ignition switch? Acura Integra
I think the switch in the locked position, is not allowing other voltages to go to the rest of the engine and car. Only the starter realise seems to work. Without power on the ignition, the motor can't start.
Try wiggling out the key, so you can use a better key, or at least can find out what is blocking the main switch.
Mar 31, 2015 | Acura Integra Cars & Trucks
I have a 1990 acura integra and the other morning when i went to start it, everything is dead. no lights no nothing. the only thing that will work is the hazards. when i take the hot wire to the bad and...
pull out and re-seat all of your fuses
Check that your battery connections are solid and not full of junk.
Unhook the clamps and use a wire brush to clean them and the battery terminals
Try it again.
Let me know if that changed anything.
Aug 18, 2013 | 1991 Acura Integra Hatchback
How to reset a brake pedal alarm
Simplest method I know is to simply disconnect the battery for 5 minutes to clear memory then use proper sequence to re-initiate if there is a separate battery back-up that will have to be disconnected as well.
Sep 07, 2017 | Vehicle Parts & Accessories
2002 acura 3.2 tl radio code errors
You will have to go to dealer to have unlocked. The vehicle has built in theft lock system in radio. Most of them have code stored in radio that needs to be pulled before removing battery.
Jul 21, 2010 | 2002 Acura 3.2TL
Hi, i need a code to my factory acura integra radio. its a factory radio and the Serial Number is 96F504420 / Model number 39100-ST7-A500 / Ref number CQ-JH9610A / Manufactured Janurary 1999. I changed the...
Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Jul 14, 2010 | 1994 Acura Integra
How to change a starter on 92 acura integra RS. how many bolts are attached
There are two bolts. One on top and one under the starter. It is best done by removing the rubber air intake tube and the battery. The bottom bolt is difficult but with a ratchet, socket and a couple of extensions it can be done. Disconnect the battery before disconnecting the wires to the starter.
Dec 06, 2009 | 1991 Acura Integra Hatchback
Fuse diagram issue acura integra
it should be printed on the inside lid of the two fuse boxes...also it's printed in the owners manual.
Jun 17, 2009 | 1997 Acura Integra Type R
I need the code radio for acura integra ls 1997
.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 26, 2009 | 2001 Acura Integra
Radio code for Acura Integra LS-SE 1996
Well, ive solved my own radio problem LoLz! On my 1996 Acura Integra LS-S the serial number is located on the back of the radio. The dealership told me to bring it in and they will remove my radio for $9O. That's ridiculous.If you can remove it yourself then you save ninety dollars. Or just do what i did...I squeezed my lil a** under the steering wheel and peeked behind the indash thingy where the radio is held and with a flashlight i was just barely able to see the serial number. I dont know if the serial numbers are all the same for all the makes, models and years like mine. But heres what i got. The serial number is: PH22481 the code for the radio is 26162. I called my local Honda dealer and gave the serial number and they gave me the code over the phone. If it doesnt work try disconnecting the battery for about 6O seconds and try again. Good luck and i hope this helps. FOR I FINALLY HAVE MUSIC!!!! YAY!!!
Jul 30, 2008 | 2001 Acura Integra
Car Audio & Video Logo
145 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
