Question about RCA 14F512T 14" TV
TV turns off within seconds of coming on
The tv comes on, sounds good and picture looks good for about 2 seconds. Not long enough to make any adjustments if need. What might be the problem??
The tve have no sounds
Posted on May 11, 2010
After I turn on the TV, there is sound but there is no picture at all... sometimes the picture comes on after couple seconds later it goes off... also the timer/standby indicator is blinking continuosly......
This is a good indication that the picture tube is starting to fail. If you feel comfortable with the back cover off, try the following:
1) Remove the back cover (set the unit on the floor)
2) Locate the flyback transformer (part with large red wire coming out the top)
3) There will be one or two controls on it. One should be labeled screen and the other focus.
4) Turn the screen control slightly clockwise.
If the picture remains on, then the tube is starting to fail and the "fix" will buy you enough time to locate a replacement.
Update this with the results,
Thanks,
Dan
Dec 22, 2009 | Sony KV-32V42 32" TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Turn the tv on, 1-2sec's l8r it turns off
sounds like the TV has a damaged power supply, most like caused by a bad capacitor on the power board, the capacitor exploded and leaked all the gases which stores electricity, so the power board isn't getting enough flow of electricity for the tv to stay on, very easy fix if you know what to do and have good soldering skills.
May 10, 2009 | 2003 Mitsubishi Outlander
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Vs-50609
Good Day, checho3435;
Look for fluid on the PCB's or check these items:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source). Good Luck, big IRISH>
Jul 30, 2008 | Mitsubishi WS-55807 TV
RCA 14F512T 14" TV Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
