Question about Pioneer VSX-D411 Receiver
After unit is on for about 15 minutes it clicks into a buzzing noise & when turned off pops. if i leave it off for about 45 minutes it works again for about 15 minutes, but if i turn it off & back on it still buzzing
  • 2 more comments
  • ld4d01 May 11, 2010
    I am not sure what you are asking but will answer to the best of my knowledge. I am using the fiberoptic connection from my samsung hdtv to my pioneer reciever. I think that would be my input source, and I am using the TV/SAT & it is set on 5-stereo advanced surround. I hope this is what you asked
  •  Aaron
    Aaron May 11, 2010
    Hello FixYa customer, What input source or sound field are you using when you get the buzz? Thanks
    to procolortv, yes the buzzing noise is coming from all 5 speakers however I can almost drown out the buzz if I crank up the volume, so the buzzing noise doesnt go up when the volume is turned up, I can hear the buzzing best at a very little or no volume. My input is on TV/SAT & 5 speaker stereo advanced surround setting. I am listening to my unit right now & is working perfectly, its just a matter of time before it pops into the buzzing sound & drives me crazy, its very frustrating since I love to watch blue ray concerts
    to SciPhinx, I was thinking it was an overheating problem also because it just makes sense. in your opinion would it be very expensive to get it worked on or would I be better off buying another reciever? I have had the unit app. 5 or 6 years, is that good or should I expect many more years of service from my pioneer VSX-D411 if repaired? Thanks
  • 25 Answers
First I would like to verify that the buzzing noise is from the speakers, and or subwoofer and goes up and down with the volume control. 2nd if it is a noise inside the receiver then that would take us in a different direction, possibly to a chattering power or speaker protection relay.
Back to the intent of the first post, I was trying to determine if you were getting an analog hum or digital processing error in the audio.
So knowing which input, surround, on/off, DSP on/of settings would steer us in the proper direction.
The turn off pop is interesting, because it may indicate a voltage off set being applied/removed to the speakers or an audio processing malfunction.
An experienced technician would first verify the power supply voltages, speaker offset voltages and bias, and then isolate to the analog or DSP section.
Thank you for using FixYa
Posted on May 11, 2010
    Guru:
  • 125 Answers
It seems like some component(s) become over heated by the time. It could be caused by either some faulty component(I guess Capacitor or Transistor in which case they must be replaced) or bad heat transfer(radiator, mounted on power transistors) that must be resoldered and/or screws/clips must be tightened.
Good luck
SciPhinx
  • Bru Sha Aug 23, 2010
    Sorry that i didn't see your following comment. How much it will cost depends on two main factors.
    One who does the job and second what the problem is. Some components are very rare and hard to get hence quite expensive. The technicians expertise determines the time and effort needed to localize the problem and repairing the unit. I was looking att some receivers for a while back and saw two from Sony with good specs for under 200 bux. at BestBuy. Sony makes good and affordable stuff imo. I'd suggest you buy a new one cuz even if you repair it often such problems put stress on other components weakening them and you might need to repair it again soon.
    GL
    Bruce
    Problem Solver:
  • 4 Answers
Hi Id4d01,
In order to eliminate the overheating possibility, have you tried taking your receiver out of whatever enclosed space you have it, and run it like that?
Obviously this is not a solution, but rather a troubleshooting suggestion. If the receiver runs longer without popping and buzzing, then you have confirmed that heat is the issue. If it doesn't occur at all, then putting the receiver in a bigger enclosure and making sure nothing is lying on top of it is a possible solution. If the popping is delayed (i.e. it takes 30 min instead of 15 min), then repairs would be in order.
Cheers!
Iordan
Posted on Aug 10, 2010
Tip
Manually defrost with a heat gun/blow dryer, pour water on ice if posssible,...
If your refrigerator runs but it does not get cold, follow these steps to determine the cause and implement a repair.
There are three common causes of this problem. First, the fan in the freezer is not working. Second, the coils in the freezer are frozen with ice. Lastly, the freon may have leaked out of the system.
Solution #1: When the compressor is running (you can hear it), open the freezer and listen for the fan running. It is usually located in the back of the freezer near the top. You can see an opening in the back panel where the air comes out. Hold your hand over the opening to feel for air flow. If there is no air flow or you cannot hear the fan running, this is your problem. Double check with a volt meter to be sure. You can access the fan by removing the back panel from the freezer. With the compressor running, touch the leads on your voltmeter to the terminals on the fan. If you have line voltage, then the fan is bad and must be replaced. You can purchase a new fan at an appliance parts store or an internet parts store. Get the model number from the inside wall of the refrigerator so you can search for parts for your refrigerator.
Solution #2: Remove the rear panel from the freezer. Look if the coils are frozen with ice. If they are, turn the refrigerator off and thaw all of the ice. After reinstalling the rear panel, the refrigerator/freezer will get cold again. In some cases, the problem will reoccur within a few days because of a problem in the defrost circuit. At this point, it will be necessary to get a copy of the wiring diagram for your refrigerator from the manufacturer and test the defrost timer, defrost heater, and defrost temperature sensor. Replacement parts are available from appliance stores. Have your model number handy in order to search for the parts you need. They will have exploded view drawings of your refrigerator to help you locate the component you need.
Solution #3: Remove the rear panel from the freezer to expose the coils. Touch the coils with the compressor running. If they are not cold to the touch, the freon has leaked out or there is a problem with the compressor. It is not a good idea to repair a refrigerator in this case. The repair could cost as much as a new refrigerator, and specialized tools are required.
on Apr 24, 2010 | Refrigerators
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Buzzing noise
i contacted danby and they told me that is how the unit was built. the buzzer would go off for about 1 minute and then would start up about 15 minutes later. I have decided not to buy any more products from this company. They should state this in their product literature.
Sep 11, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Noise & Clicking at regular intervals on working Kenmore 72214
yea that is the compressor relay, you will start to notice your food to thaw out and get bad. try to unplug for about an hour. if then it still does that call www.whirlpoolpartssurplus.com and get a relay kit.
May 06, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
A buzzing noise comes on every 2 mins for about 45 seconds
2 things, eithere the ice maker is "calling for water" and your not hiiked to a water supply. in which case simply turn of ice maker till you restore water to the machine.
ohter noise sounds if perhaps the compressor is not cycling correctly, overheating, nad when tries to restart you hear it try for 10 secs or so, then click off. in which case youll seee the freezer stating to lose "cool" especially "wet ice" and/or soft ice cream products.. if this is the case you can try to clean the coils under/behind the refrig, and may need to replace the starting device mounted to the side of the compressor
Mar 31, 2009 | Frigidaire FRS26R4A Side by Side...
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
I have recently acquired a old Denon AVR3801 Home cinema Receiver. I have plugged it all up and switched it on, but although the system seems to work quite nicely, the amp itself makes a buzzing/humming...
The solution of leaving the thing on all the time would certainly work, but most of the time a buzzing sound inside a relatively robust audio amplifier is being caused by the huge transformer coil in the thing. Or wires that are in close proximity thereto.
In some ways, you're blessed that the buzzing is coming from the unit itself, and not through the loudspeakers.
Mar 06, 2009 | Denon AVR-3801 Receiver
Buzzing plenum heater
is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Jan 04, 2009 | Heating & Cooling
Pioneer VSX-D411 Receiver Logo
317 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
