Question about Arris SURFboard SB4200 Modem
I'm am trying to make my internet faster because it is to slow and i want into the http://192.168.100.1/hack.html and added the File Name:d11_m_speedtierextreme2_c01.cm and TFTP Server IP:68.87.68.35 and its still not working,but a comcast person told me the ip and file name dont work anymore for my modem in my area so can someone help please?
  • 3940 Answers
SOURCE: My pc won't connect to the internet
It is the MAC address that needs to be scrubbed from the modem.
power off the desktop, power off the modem, unplug the data cable from the modem, unplug the POWER connection to the modem.
WAIT 3 MINUTES
Connect power to modem, let it reset
Connect data cable to Modem
power on computer
Modem should now connect & work with desktop.
Each time you switch between systems, you may have to do this. More than enough to make me buy a router. =)
Please rate the post. =)
Posted on Jul 15, 2008
frcs68
  • 1605 Answers
SOURCE: no ip address from modem to linksys wrt160 n router
1).turn off the modem and the router.disconnected from the Internet ISP. and the computer.
2).disconnect the router from the modem.
3).turn on the modem.
4).connect the router to the modem, and turn on the router.
5).connected the computer to the router, adn turn on the computer.
if you are using wireless, waited about 5 minutes before turning it on.
goto control panel>>wireless network, and configure the wireless seting.
Posted on Nov 18, 2008
  • 17 Answers
SOURCE: IP ADD.
Did you try and reset the configuration on the router? There should be a small pin hole allowing you to access the reset configuration button with the end of a paper clip. Power on the router while the reset button is held in and wait for a few seconds before taking the paper clip out. You will loose any configuration that was on the router so if your provider had special configurations you will need to replace those configurations once you have access.
Posted on Jun 05, 2009
  • 4 Answers
SOURCE: Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Posted on Jun 14, 2009
MNfisherman
  • 11896 Answers
SOURCE: i want 2 play my ps3 online using my arris modem
You should use a router, but if you cant, try hooking everything up like normal, then pull the power cord on modem for 10 full seconds, hook back up, wait 5 minutes and then try.
Posted on Jan 23, 2010
How to make your internet run faster?
There is a lot of things that slow your computer's internet connection. You have to keep your computer optimized, such as cleaning your web browser's cache files and your hard drive could be needing maintenance. Run a few ISP speed tests, Speakeasy,Comcast, are just a few. If you are a wireless connection download this freeware program which can help you find a better connection, Go to http://www.techspot.com/downloads/5936-inssider.html , PS check your internet provider to see how fast a connection your paying for.
Oct 04, 2014 | Computers & Internet
Tip
Tips to Make A Laptop Faster
Run a good<b> registry cleaner</b>: Registration of a <b>laptop</b> is absolutely intrinsic to its functioning and, therefore, any corruption or errors in the registry can take your<b> laptop</b> running slow. To keep your registry clean and make sure it is not damaged, run a <b>registry cleaner</b> regularly in your <b>laptop</b>.<br /> <br /> Delete all Temporary Internet Files: When surfing the Internet and visit various Web sites, an imprint of the Web page or a temporary file is stored on your <b>laptop</b>. Contrary to its name, these temporary Internet files on your <b>laptop</b> are more than usual and therefore slow performance. Therefore, you must delete all temporary Internet files regularly for your <b>laptop faster</b>.<br /> <br /> Defragmenting the <b>laptop</b>: Most of the time when the registration information or data on the <b>laptop</b> is placed anywhere in the system. This results in a lot of processing time and therefore slows down the laptop. Therefore, to make your laptop faster, to be defragmented regularly. By obtaining the defragmentation is complete, ensure that all data and information stored on the laptop is simplified. This allows easy access to information, saving time, and therefore helps your laptop run faster.<br /> <br />
on Jan 17, 2011 | Computers & Internet
How can i make my computer run faster
do you use P2P (Peer to Peer) file sharing programs? If so then try turning the file sharing program off, as file sharing programs use up alot of bandwidth some broadband providers limit the speed you can use the internet if you are using file sharing programs.
If you turn off the file sharing program your broadband speed goes back to normal .
I faced the same problem ,after doing this i checked my speed from ScanMySpeed.com apparently my internet speed is faster than before.
If these doesn't apply ,there is a chance you may have a virus on your computer. A computer virus is likely to not just slow your broadband and Internet down but your computer too.
Mar 20, 2014 | Computers & Internet
Slow
First of all try clearing cookies,browser history and cache,avoid running electronic devices at once,upgrade your modem or router to a newer model and have a periodic check in your modem ventilation, or do you use P2P (Peer to Peer) file sharing programs? If so then try turning the file sharing program off, as file sharing programs use up alot of bandwidth some broadband providers limit the speed you can use the internet if you are using file sharing programs.
I faced the same problem ,after doing this i checked my speed from http://www.scanmyspeed.com apparently my internet speed is faster than before.
If these doesn't apply ,there is a chance you may have a virus on your computer. A computer virus is likely to not just slow your broadband and Internet down but your computer too. ScanmySpeed Check my Internet Speed
Jan 15, 2014 | Computers & Internet
I have forgotten my serial number
If you are trying to recover a key of an already installed program on your computer there are freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry.
It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping.
also
Its illegal for anyone to provide serial keys for programs that have retail values set on them there are lots of freeware alternatives on the internet.
Download Anything Faster.
We all know that internet downloads can take quite a long time to download.
If your looking to make your downloading faster - you're reading the right article.
Accelerating your downloads is easier than you think.
There are a few tricks to speed up any download you have.
The most important thing to consider while trying to download something - remember what kind of internet connection you have.
If you have dial-up, you should be prepared to wait awhile. If you have DSL or cable speed internet and it's still going slower than a snail, chances are you have too much going on with your computer. I will explain further!
When downloading anything from the internet, you shouldn't have too many other applications or programs running.
Keep it simple. Say, your downloading a song - don't keep searching the internet and IMing someone at the same time.
Close all other programs running until your done downloading your files.
When your download is going way too slow, try hitting Ctrl + Alt + Del and go to your task manager for Windows.
A lot of times, programs are still running that you have no idea about.
Left click programs and end the task.
This can accelerate any download, even if your using dial-up still.
If you are using a router for your DSL, you might want to consider unhooking the router and plugging in your modem directly to your computer until your done downloading files.
A lot of times, your router strength isn't half as strong as your actual modem connection.
You should always consider getting a download manager to accelerate and manage downloading. This can make everything so much easier and faster.
I would suggest downloading the Firefox download manager.
http://download.cnet.com/mozilla-firefox/3000-2356_4-10208565.html
Or orbit download manager
http://download.cnet.com/orbit-downloader/3000-2071_4-10600926.html
You can pick and choose which downloads you want to accelerate and pause.
http://download.cnet.com/bittorrent/3000-2196_4-10211384.html
Search the Internet for torrent files, and download and upload files.
Internet Download Accelerator lets you conveniently manage downloads by organizing them in categories with automatic category detection option. Free
http://download.cnet.com/internet-download-accelerator/3000-2071_4-10190491.html
http://technojourney.com/softwares/free-best-internet-download-managers-accelerators-windows7-windowsxp-vista-full-version/
http://www.freedownloadmanager.org/download.htm
We are glad to inform you that a new version of FDM 3.9 has been recently released.
It includes a support for Firefox 10-14, as well as updated torrents core library, updated help file, and a pack of general bug fixes.
Please proceed to our download page to get more information.
also you might try
http://en.softonic.com/s/internet-download-manager-serial-number
http://www.soft82.com/free/idm-serial-number/
May 21, 2013 | Tonec Internet Download Manager
Download for pc
http://download.cnet.com/2000-20_4.html Place a tick in either windows software or the all software box on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right
Download Anything Faster. We all know that internet downloads can take quite a long time to download. If your looking to make your downloading faster - you're reading the right article. Accelerating your downloads is easier than you think. There are a few tricks to speed up any download you have.
The most important thing to consider while trying to download something - remember what kind of internet connection you have. If you have dial-up, you should be prepared to wait awhile. If you have DSL or cable speed internet and it's still going slower than a snail, chances are you have too much going on with your computer. I will explain further! When downloading anything from the internet, you shouldn't have too many other applications or programs running. Keep it simple. Say, your downloading a song - don't keep searching the internet and IMing someone at the same time. Close all other programs running until your done downloading your files. When your download is going way too slow, try hitting Ctrl + Alt + Del and go to your task manager for Windows. A lot of times, programs are still running that you have no idea about. Left click programs and end the task. This can accelerate any download, even if your using dial-up still. If you are using a router for your DSL, you might want to consider unhooking the router and plugging in your modem directly to your computer until your done downloading files. A lot of times, your router strength isn't half as strong as your actual modem connection. You should always consider getting a download manager to accelerate and manage downloading. This can make everything so much easier and faster. I would suggest downloading the Firefox download manager. http://download.cnet.com/mozilla-firefox/3000-2356_4-10208565.html Or orbit download manager http://download.cnet.com/orbit-downloader/3000-2071_4-10600926.html You can pick and choose which downloads you want to accelerate and pause. It can come in pretty handy! also http://www.freedownloadmanager.org/download.htm We are glad to inform you that a new version of FDM 3.9 has been recently released. It includes a support for Firefox 10-14, as well as updated torrents core library, updated help file, and a pack of general bug fixes. Please proceed to our download page to get more information. Hope this helps
Jan 21, 2013 | Computers & Internet
Very slow computer
You are frustrated with the slow performance of your Dell laptop? You can quickly fix this slow PC problem and prevent it from happening again, all with a few clicks. Simply apply some easy tips as discussed below to make your Dell laptop/computer make faster - http://technical-support-squad.blogspot.in/2012/08/make-dell-laptop-run-faster-how-to.html
Feb 12, 2012 | Dell Inspiron B130 Notebook
When I receive a email with a link, I double click on the link but I can't open it up. If i highlight it and click on search, it will usually open but not all of the time. It has only been doing this for...
Hi!
Internet Explorer is very slow when trying to browse the internet. It means, that when you try to open a link, a url and or a website the loading of the web page is very slow.
I do suggest that you change your Internet browser to Mozilla Firefox. This internet browser is comparatively faster than Internet Explorer.
Download this from this link
http://www.mozilla.com/en-US/products/download.html?name=ALBERT+ALEX+JIMMY&id=141&announcement_id=35&product=firefox-3.0.1&os=win&lang=en-US
Click this link. When a small window appear click the Save File button to daownload it. After downloading, double click this file to run and install in your computer. Make it as your default browser.
Now when you click any links from your att.yahoo, the links will load faster in mozilla firefox.
Post back if you still have problems. Here, I can assist you further, just click the add your comments to post your message
Feb 04, 2011 | Yahoo Mail
Msvcrt.dll or .d11 says this file was not found. I cannot get it to start. Says fatal error - shutting down.
check out this link
http://www.ehow.com/how_6372455_repair-msvcrt_dll-windows-xp.html
Oct 26, 2010 | Dell Inspiron 1525 Notebook
WEB PAGES AND DOWNLOADS ARE VERY SLOW.
Use Mozilla firefox browser whihc is beleive to be faster than Internet explorer.
You can tweak the Mozilla by following my link below
http://www.fixya.com/support/r3572414-firefox_speed_tweaks
Here is the download link
http://www.mozilla.com/en-US/firefox/firefox.html
But if you still want to use Internet explorer than tweak the Internet explorer using my earlier link, below is the link
http://www.fixya.com/support/r3591130-how_to_speed_up_http_requests_on_interne
Always use Download Manager to download anything from net except from sites like rapidshare,megaupload etc.They don't support Download Manager as they are file hosting server.
I recommend you use "Orbit Download Manager" as it is completely free and it support video download from sites like youtube.com etc
Here is the download link from whwre you can downalod Orbit Downloader
http://download.cnet.com/Orbit-Downloader/3000-2071_4-10600926.html
That's it.
Make Sure your system is free from virus, trojans or spyware or adware, they slow down the system as well as consumed Internet bandwidth too.Scan your PC with a Good Antivirus but I recommend you to use any Internet security suite.
Feb 01, 2010 | Toshiba Satellite Pro L300 Notebook
Arris SURFboard SB4200 Modem Logo
140 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
