Question about Gateway FPD1975W 19" LCD Monitor
The monitor of my laptop always turning off
When i switch on my laptop, and after some few minutes.. its monitor got turned off but its CPU is still running.. pleae help....
  • 11,361 Answers
Try hooking up the external and THEN turn on the laptop to see if you get the picture OK. Most failure are due to bad backlight inverter board, you can also check to see if the connection to the inverter baord is OK, it is located under the front bezel of the laptop. Learn more here: www.insidemylaptop.com
http://s807.photobucket.com/home/budm/allalbums
Posted on May 11, 2010
Monitor cuts off
This could be the result of a few different things. If you haven't checked, click start, control panel, performance and maintenance, and power options. In this box, there should be numerous setting possibly pertaining to your specific problem. Also, ensure your cpu fan is running. A failed cpu fan will make your monitor turn off. Additionally you will have to make sure your power supply isn't bad. The easy fix is the first of the issues though.
May 26, 2010 | E-Machines eMachines Monitor E15T4
D915GAG motherbord
cpu could be heating up or try anther video card make sure the mem is for that board
Mar 31, 2010 | Intel D915GAG Socket 775 Motherboard -...
Screen goes black when turned down and it does
try removing suspend on lid close .. refer to your laptop manual .. try this too disable herbernation also ..if nothing works check if you have latest graphic driver !! it might be a problem with ACPI .. but my two solutions should work !!!
Mar 10, 2010 | ASUS W7S-3P100E T7500 PC Desktop
The computer is an acer 5630 laptop. Before i changed the motherboard I would turn on the laptop and five seconds later The fan would shut off and all the lights would stay on. I purchased a motherboard...
fan always start working when u switch on the laptop, then it stop because it monitor your cpu temprature if CPU temp is blow the level of heating then it stay stop and if it exceed the limit of cooling then fan automatically start to just kick out heat of CPU, so it is normal, but tell me did u get display when fan switch off? let me know
Aug 24, 2009 | Computers & Internet
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Acer Aspire 3100 Laptop Monitor will not turn on
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Dec 17, 2008 | Computers & Internet
HP Presario V2000 Laptop Turning off after a few minutes on
Sounds more like the CPU is over heating. This is a fairly common fault on laptops after dust hair etc build up in the fins of the heatsink from the cpu.
After it blocks up, the fan can not push air through it to cool the cpu down and so the laptop goes into thermal shutdown to protect itself.
May 14, 2008 | HP Compaq Presario V2000 Notebook
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
