Question about Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
Coil burner stays on even when in the off position on my maytag range.
    President:
  • 949 Answers
The switch control for the burner has gone bad.
If you can get me the model and serial numbers from the tag on the range and tell me which coil is having the trouble I can assist with repair part numbers and tell you how to repair if needed.
Posted on May 11, 2010
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
The cooktop indicator light is still on even when all the knobs are in the Off position on my Whirlpool range model RF265LXTY
MOST SMOOTH TOP ELECTRIC STOVES THE INDICATOR LIGHT WILL STAY ON UNTIL THE BURNER COOLS OFF.IF THE BURNER IS COOLED THEN ONE OF YOUR SURFACE BURNER SWITCHES IS BAD AND WILL NEED REPLACEMENT .HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Whirlpool RF265LXT Range
Glow coil glows but wo'nt ignite burner. can
if you have used the self clean function you may have burned up the ignitor they are rated for about 1000 deg for just about a minute but when you clean it stays around 800-900 deg for about an hour or so. You may just need to replace the ceramic ignitor. as for the gas, the valve will only stay open for a few seconds, if the oven doesnt recognize a flame the gas valve will close.
Jul 26, 2009 | Maytag PER5710 Performa Electric Kitchen...
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Igniter stays on on all four burners all the time. Had to turn off breaker to stop. Started sparking all by itself with burner in the off position.
Usually this happens when water or some type of liquid gets on one or more of the igniter switches. Let it dry for 48 hours, turn the power back on and see if it keeps on clicking. If it does, one of the switches needs to be replaced. Not a very difficult job. Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 05, 2006 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range Logo
61 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
