Question about Singer 57817 Computerized Sewing Machine
Cant thread bobbin
Thread not being pikup by needle
was just given singer57817
    Scholar:
  • 35 Answers
To learn how to solve thread bobbin and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
I cant get my bobbin to meet the needle thread
Be sure to install a brand new needle. Check that it is threaded correctly (top and bobbin).
If it still will not pick up the bobbin thread, it may have a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin thread. You can search the internet for web sites and videos dealing with sewing machine timing or take it for service.
Oct 26, 2016 | Sewing Machines
I have just been given a singer melodie 40.When I start to sew, material is stopped by bobbin? Bobbin is breaking off bits of thread underneath?
Try a brand new needle. Make sure the thread is suitable to the needle and fabric you are using. AVOID old or bargain bin threads. Spend an extra dollar or two for good thread.
All About Needles
Check that there are no loose threads stuck in the upper thread path, ie the tension disk.
ALWAYS RAISE the presser foot when threading the upper thread. Verify that the thread path is correct. Mis-threading will invariably cause broken thread.
Clean out the bobbin area & feed dogs of any lint and loose threads. Check that the bobbin has been installed & threaded correctly and turning the right direction in the bobbin case.
Manually rotate the handwheel one turn until the upper thread grabs the the bobbin thread. Pull it the rest of the way to the top. When beginning to stitch, start slowly and gently hold both thread tails in your left hand until it has made a couple of stitches.
How and Why to Bring up the Bobbin Thread
If you have a manual, make sure you follow the maintenance tips. If the machine needs oiling, be sure to follow the instructions using only fresh good quality sewing machine oil. Most machines that have been given as gifts from a sewist's stash may not have been maintained regularly.
If it still does not stitch properly, take it for service. It could have a timing issue, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
Singer melodie 40 user manual
Oct 25, 2016 | Singer Sewing Machines
Needle cant grab thread in bobbin
Make sure you get a new needle, put it in RIGHT. usually flat side to back. Make sure your bobbin is turning in the case CLOCKWISE
Usually it is a bent needle, or it is in wrong. Also, make sure your thread in going through the eye of the needle, and not twisted around the needle.
Mar 22, 2014 | Sewing Machines
I cant get the needle to catch the bobbin thread. I just received the machine, i might not be doing it write? any suggestions
This has to be done by hand.
Raise the presser foot, then thread all the way down to the needle. Put in the full bobbin with thread end loose and visible. Hold the end of the thread in the needle with one hand and carefully turn the wheel so that the needle lowers and lifts the bobbin thread. Place both threads behind the presser foot. Now you can sew.
Jan 24, 2011 | Brother XL3750 Mechanical Sewing Machine
Have been given an old frister rossmann 402 machine with no maual so i cant work out why it sews some stitches and becomes hooked up underneath by loopy threads
change the needle
rethread the top thread make sure the thread doesn't come off the thread take up lever
check the bobbin area for lint or loose threads
also rethread the bobbin in the bobbin case & reinsert it
also check the top thread tension try 3 or 4
Nov 04, 2010 | Sewing Machines
I was given this machine and I can't get the bobbin thread to come up. I place the bobbin in the machine then snap the leave down. I put the needle down and when I raise it back up the bobbin thread...
try these suggestions
Check your needle to see if it's damaged
Make sure you have a 3-5 inch thread tail on both top thread & bobbin
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of machine & slowly lower needle into bobbin area & see if it will pick up the bobbin thread that way
Oct 08, 2010 | Singer Sewing Machines
I cant get my needle to pick up the bobbin thread
You can download a copy of your manual for free on www.singerco.com under customer support if you need to see the correct way to thread your machine. Hope this helps
Oct 01, 2010 | Singer 8280 Mechanical Sewing Machine
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Thread caught up around bobbin!
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Nov 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Singer 57817 Computerized Sewing Machine Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
