Question about Vacuums
We had to take the machine apart just to see that the belt had broken after only 5 use's . We can not see how we are ever going to put the new belt back on. do you have instructions on how to take the belt off and how to put a new one on? Please send me one.
  • Her400 Apr 12, 2008
    I own a windtunnel bagged canister. Using it the first time, the belt slipped off (did not snap or break) took the screws out and pulled it back on per instructions, and lo and behold - did it again.
    I notice there is no "nub" or whatever (cap?) on the end of the motor pulley where the belt attaches. -that looks wrong, there needs to be something to keep that belt on there? That motor pulley narrows near the edge, so the belt would naturally slip off during use...
    But the diagram in the users manuel clearly shows it with NO nub/cap.
    Even bought a new belt and that did not work. This thing has only been used (partially,because of the belt problem) a few times.
    Thank you
    Help!
I have a Panasonic MC-V5746 upright vacuum. According to the booklet,
MAKE SURE UNIT IS UNPLUGGED.
1. Place carpet-bare floor selector in "carpet" position.
2. Remove lower plate (there are two screws in the middle of the lower plate), and a pair of locking tabs located near the wheels that you push toward the wheels.
3. Carefully pull agitator brush up and out and clean it.
4. Look new belt around the motor shaft (I had to turn the belt edgewise to get it back in there). On my unit, there are two shafts. Put it around the one furthest back and don't worry if it doesn't touch the other one.
5. Pull the other end of the belt and loop it around the "brush pulley" which is the narrow track on one end of the brush.
6. reinstall agitator back into nozzle housing grooves.
7. Turn the brush by hand to make sure it moves smoothly and isn't pinched or twisted.
8. Reinstall lower plate.
Posted on Mar 28, 2008
SOURCE:
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
How to install broken belt
Why would you want to put in a broken belt?
Turn the machine upside down. There are two clamps that hold the sole plate on, un click then. This will reveal the 'belt alley' where the belt runs from the motor to the roller. Lift the roller out of the slots. Take this time to clean all the hair and threads off the roller.
Put the new belt over the wooden pulley on the roller and put it almost back in. Put the other end of the belt over the motor shaft. Stretch the belt by returning the roller to its slot. Put the sole plate back on - snap the clips - Presto.
Simple
Thanks for your question today.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater bar won't turn. Assume the belt is off or broken but can't see how to get to it. Help!
If the machine is still under warranty, you'll want to take it to an authorized service center for repair. If not, it can be pretty tricky to take the power head apart, replace the belt, and get it put back together correctly. I still recommend taking it into a shop for service.
Aug 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Hoover Turbo EmPower 4600 and the roller will not turn when we turn on the vacuum. The vacuum is fairly new, and hasn't seen too much use, but now the roller won't turn, so it's not picking...
The beater belt is broken. There are 4 phillips head screws on the outside (2 on top of the base on either side of the upright, and 2 on the front edge on the underside of the base near front edge). and 4 phillips head screws on the inside (holding the guard cover over the beater bar). The belt is about $3 (part number 38528040). Take out the beater bar and put the new belt around it. Then put the other end around the metal bar and stretch the belt taut as you position the beater bar back into its channel slots. Replace the guard and top cover and you should be good to go...
Jan 23, 2010 | Hoover Vacuums
Hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Mar 22, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Putting on a belt on a vacuum
Greetings from GoVacuum.com,
Replacing a Belt on an Upright vacuum can vary from model to model, but it is basically going to be the same for most upright models.
First you will need to access the belt. Most upright vacuums this is done by turning the machine upside down, and most you'll need to remove the bottom plate by unscrewing (usually 4) screws that hold the plate on. You should see screws that are closest to the actual roller brush, simply remove these screws, and take the bottom plate off. If the machine is a Eureka, or Kenmore, the top agitator housing will be removed from the top of the vacuum, not the bottom.
Once you have removed the bottom plate, or top agitator housing, you should be able to see the belt (or broken belt) along with the roller brush. Remove the broken belt. Make sure that you purchase the correct belt by taking the make, and the model number (located on the back or bottom of the machine). Please note that a broken belt may be 4-5 inches longer then a new belt, as they stretch a lot before they finally break.
Once you have the new belt, you will need to remove the roller brush. Pay attention to how the roller brush fits into the agitator housing, usually there will be fittings on the end of the roller that have to be put in a specific place, or in a certain way to work right. After the roller brush is taken out of the machine, you will need to wrap one end of the belt around a metal pulley on the opposite side of the roller brush. Most pulleys are located where the main housing (handle part) of the vacuum meet the the agitator (floor part) part of the machine. Anyways, wrap one end of the belt around the pulley, and then put the roller brush through the other end of the belt. This is where you'll need to put some elbow grease into it. You'll need to stretch the roller brush and belt so that the brush and belt are stretched back to the place where you took the roller brush out of the vacuum.
Once you have replaced the roller brush with a new belt around it, pull the belt a few times to make sure that the brush spins while you are pulling it, to ensure that the belt is not pinched, and is spinning freely.
I hope this helps. Here's a video showing how to replace the belt on a Hoover Windtunnel Self Propelled model; Feel free to email me if you'd like to send me the model number of your vacuum, this way I can be a little more specific, and give you part numbers. I have all belts for all vacuums in stock. Email; [email protected] 1-866-468-2288. You may also chat with me by going to our website, www.govacuum.com, and clicking in the top right part of the page. Thanks!
Oct 11, 2008 | Vacuums
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
Vacuums Logo
73 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
