Question about Maxtor Hard Drive
I built a computer from scratch and bought a used hard drive that was wiped clean. The computer system loads as far as windows setup but does not go any further. Someone told me to put make sure the driver is set on master but that doesn't seem to be helping.
  • 79 Answers
Try this video from Computeractive re hard disk http://www.computeractive.co.uk/computeractive/video/2246207/prepare-hard-disk. Hope this helps you.
Regards Bill
Posted on May 11, 2010
Don't I have to wipe the C Drive clean, and if so how do I do that
If you wipe your drive you will need to load another operating system on it unless you want to sell it ?
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart or if you are using a USB insert your usb drive click start right click on my computer select open you should see your USB drive right click then select format another way is to control panel administrive tools,computer management disk management right click on your drive select format hope this helps www.WipeDrive.com
Jan 19, 2013 | Microsoft Windows XP Home Edition
Unistall windows 8 pro
You have to install another operating system
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
Formatting a hard drive to erase its contents does not mean the files are necessarily gone forever. Using data-recovery software, someone still could retrieve sensitive data and files from your hard drive even after you've formatted it. Instead of simply formatting your hard drive, use disc-cleaning software to permanently erase its contents. Disc-cleaning programs work by repeatedly overwriting the contents of a hard drive with random data patterns, making it virtually impossible to recover the original files. Download and install the freeware program Active@ KillDisk (see Below). http://www.killdisk.com/downloadfree.htm Click the Windows "Start" button and select KillDisk from the "All Programs" list. Click the check box next to the hard drive you want to erase in the "System Local Disks" menu. Press the "Kill" button. Select the erasing method you want to use from the "Erase Method" drop-down menu. Active@ recommends using the "US DoD 5220.22-M" method. Click "Start" to begin erasing the hard drive. Download and install the freeware program Hard Drive Eraser (see Below). http://www.harddriveeraser.org/ Click the Windows "Start" button and select Hard Drive Eraser from the "All Programs" list. Check the radio button next to the hard drive you want to erase under "Select Drive to Erase." Select the erasing method you want to use from the "Shredding Scheme" drop-down menu. The developers of Hard Drive Eraser recommend "DoD 5220-22 M" Press the "Start" button to begin erasing the hard drive. Download and install Iolo DriverScrubber (see Below). Click the "Windows" Start button, "All http://www.iolo.com/ds/3/ Programs" and then the DriverScrubber program icon. Click "Wipe all contents of a drive," and then click "3.5-Inch Floppy Disk." Insert a blank floppy disk and click "Next." Restart your computer with the floppy disk still inserted. Your computer will boot directly to DriveScrubber. Press the down arrow on your keyboard to highlight the hard drive you want to format in the "Available Physical Drives" menu. Press the space bar to select the hard drive. Press "Enter" to continue. Press the down arrow to highlight "Seven Overwrites" in the "Available Data Wiping Methods" menu, and then press the space bar to select it. Press "Enter" to continue. Press "CTRL," "ALT," "Shift" and "W" at the same time to wipe the hard drive. Hope this helps.
b>
Dec 30, 2012 | Dell Computers & Internet
How can i restore a toshiba equium l20-197 back to factory settings
System restore will not do what your asking.
However there is a way but you will need a Installation cd Assume you have Windows XP
Then you need to borrow or buy a Windows XP Home Edition or Pro
You can buy one used from Ebay.
There are two options !.Repair install this will save all files/data on your hard drive.
Follow these instructions to Repair install.
Boot the computer using the XP CD.
You may need to change the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup.
Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console).
I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair.
If Repair is not one of the options, END setup.
After the reboot
Setup will copy the necessary files to the hard drive and reboot.
Do not press any key to boot from CD when the message appears.
Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
2. If you want to do a clean install that will completely wipe your hard drive clean then follow the instructions from this site http://www.winsupersite.com/showcase/win...
You will then need to reload all Microsoft Windows Updates and find all other drivers and software from http://uk.computers.toshiba-europe.com/c...
Then wham bam you should be back in business.
hope this helps
Sep 27, 2012 | Toshiba Equium Computers & Internet
I have a Emachine T5212 and im trying to reformat my hard drive but my internal dvd drive is not recognized.I brought an external dvd drive,but everytime i try to erase my hard drive it tries to load from...
First you need to have media ready to install once format is compelte.
You can not format a drive you are currently using an operating system unless you run the operating system setup disc in which case you would be booting and running from cd once you start reloading you main drive.
So if you are loading windows .
Review steps below if when you boot you do not have option to select boot device
Boot you laptop / pc and get into the BIOS
<normally f2 or f8 , f12 depending on system.>
Change the BOOT order to cdrom as primary \ you may see the device as USB CD/DVD rom with the actual name of brand there.
Save and exit
Have operating system in cd/dvd rom attached to device
Once it starts to load you will see BRIEFLY in the upper left corner PRESS ANY KEY TO LOAD FROM CD ROM or something similar... stop reading this and press a key ........
From there it should prompt you for setting up a new os, I prefer linux myself but in windows or linux in the setup process you have the option of just loading the operating systems or DELETING THE PARTITIONS and FORMATTING the drive, therefore wiping i .
NOTE: THIS IS NOT WIPING YOUR DATA, if you are trying to hide something, wipe from your drive past **** you never wanna share with anyone again..... repost under how do i wipe my hard drive clean .. its a completely different story .. not hard but different.
Jul 24, 2011 | Computers & Internet
When i try the acer system recovery it keeps coming up with an error that says windows could not install and setup with resume when computer restarts..restarts ands same box pops up? cannot get past that...
Have you tried booting to the system recovery again and starting it over? Otherwise you may need to wipe it clean and start from scratch. Download a program like Darik's boot an dnuke to wipe the hard drive clean (this will destroy all data on the hard drive, including system recovery data if that is saved on the hard drive instead of CD's.) Then try the system recovery again (if it's on CD's)
Jun 24, 2011 | Acer Aspire One PC Notebook
Windows 7 need a hard drive driver compatible with my hardware. I bought a new laptop hard drive - Western Digital SATA 500GB - 7200 rpm drive. It is formatted, and when I load windows from boot drive it...
WD hard drives use drivers that are built into the operating system (OS). It is extremely rare for the built-in drivers to become damaged or corrupted. The most common reason the operating system fails to recognize a drive is that the drive is defective or damaged.
Jun 10, 2017 | Western Digital (WD5000AAKS) 500 GB SATA...
My neighbour had a hard drive failure. She put in a new hard drive but when she tries to install windows XP it starts auto setup but then comes up with a message that it cannot read a file D:/setup........
Chances are the CD is scratched or dirty. Have a look at the under-side of the CD, If it is dirty, or full of fingerprints, try cleaning it with a soft cloth wiping radially (from center out like the spokes of a bicycle wheel). If it is badly scratched get a new copy and try again.
Hope this helps ;)
Jan 26, 2011 | Compaq Evo N1000C Notebook
Wont load win xp on gx 260
There are a number of reasons why XP won't install or hangs halfway through the install process.
The main culprits are bad sectors on the hard drive. Poorly seated or faulty system memory and of course scratched CD or a dirty optical lens.
You are going to have to go through this troubleshooting process to determine what the problem is and what you have to do to resolve the problem.
Start by cleaning the install disk and the optical lens, remove and clean the system memory and the slots, check the cables and then try to reinstall.
If you run into the same problem i would be suspecting the hard drive.
As far as i know Dell have their own utility.
Turn on the computer. When the DELL™ logo appears, press <F12> immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again.
When the boot device list appears, highlight Diagnostics and press <Enter>.
If you don't have the Dell Diagnostics Utility on the computer then something like Hiren's boot CD will be able to check the drive for errors in the hard disk tools section.
Regards.
Sep 29, 2009 | Dell OptiPlex GX260 PC Desktop
System wont boot
i would slave the drive into another system revmove the data off it that i want to keep and then repartishion the drive and do a fresh install.
regards, daniel
Jan 12, 2009 | Abit IC7-G Motherboard
Maxtor Hard Drive Logo
53 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
