Question about Palm Treo 650 Handheld
Media on card stopped working correctly
My phone has been working fine lately and then just the other day most of the pictures on the card stopped working correctly. It showed some images but most of them just had a red X and wouldn't show the image. Then now none of the images on the card show up, all are the X where the picture usually is.
I deleted the pics, and then I took a picture with the camera. The picture shows up if I save it to the phone, but if I save it to the card it doesn't show up and it just shows the X over the picture.
What is causing this problem and how do I fix it?
    Novelist:
  • 170 Answers
It sounds like you could have dirt on the contacts for the SD card slot, or the SD card is failing.
I would recomend two two things to try:
1) try using a popsicle stick with paper towel over it and wet with alcohol to swab the contacts and clean them. Be sure the phone is off when you do this. Whiel alcohol does not conduct any current and is safe to use with electronics, it is always best to power off your device, remove the battery, and start with a very safe, non-powered unit.
2) try a different SD card. They're really cheap now so try one that's a reliable name brand. Your SD card could be failing.
3) try reformatting your SD card. (this is the cheapest and easiest solution, but not the most reliable if the card is failing).
Posted on Apr 29, 2008
When i turned on my computer the monitor read "no VGA signal," it was working fine the day before, do i need a new video card? if so what type do i need? or what other problem could it be?
Most likely it is the video card.... If it was working fine and all of a sudden it stopped then its usually the video card.. Has there been lightning lately, thunderstorms? That usually burns them.. You could pretty much use any Video card... Let me know if this answers your question and good luck..
Sep 09, 2011 | eMachines etower 366is PC Desktop
My phone is 3110c . It worked fine but lately when I put sd memory card in it , it's screen flash and restarts for several times and at last it turns off . This happens with all of the mem. cards
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone.Also try without the memorry card and If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 01, 2011 | Cell Phones
My camera won't let me take any pictures or look at them. Everytime I turn it on it says memory card error, card locked. i've tried moving the locked switch on the side of the card up and down but that...
Okay I think there is a sequence of errors that have happened.
According to my specification of your camera it works with an XD Picture Card NOT an SD card.
First I'm going to assume you put a new memory card in your camera to take the pictures of your "Art GCSE" If this is so then the card needed formatted to the camera (your camera manual may call this initializing) and you have inserted the correct card type. Also the maximum size of the XD card that can be used in your camera is a 512MB. Again if this was the case the camera wouldn't "see" the memory card. I'm sure the camera would have malfunctioned before you started taking your project pictures given warnings or shut down. Can you turn on the camera and see your pictures in the "Play Back" mode? Are you sure you have listed the correct camera make and model. It sounds to me as if we are talking two different cameras here because the XD Memory Card doesn't have a lock the SD memory card does The SD memory card doesn't fit in your Fuji FinePix A350 camera Also the camera you have listed here doesn't have an internal memory it has to work with a memory card Just below here is a link to a PDF Manual
Manual link in PDF format
http://www.google.ca/#hl=en&source=hp&biw=1224&bih=834&q=Fuji+FinePix+A350+PDF+manual&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=6a0673dc5c3f3912
Can you put the memory card that you feel has the pictures on it and use the camera Play Back mode and see pictures?
Jan 10, 2011 | Fuji FinePix A350 Digital Camera
How to add phone memory?
IF your phone has a place for media card save all items music,pictures,videos, to there that will give you more phone memory. if you dont have a slot for a media card you have to keep deleating you messages and keep pictures to a minimum.. if you need lot of room you want to look at changeing phone.. i hope this helps you and have a blessed day..
Apr 30, 2010 | Nokia 6280 Cellular Phone
TEXT MESSAGES WITH PICTURE ATTACHMENTS
Have you checked to see if the websessions information iis correct in order for your wifes phone to access the internet for Cingular. Go to your Main Menu and click select on the browser icon. Now scroll to find WEBSESSIONS and click SELECT. Depending on where the cell phone came from initially it will either have just a couple of choices or a lot of choices here. You need to locate either a Cingular3 or MEdia Net. These are usually what the setting name is called. You need to verify that these settings are correct for your AT&T service. I do not know if it is ok for me to put the info here. So I will tell you where you can find it.
You need to go to the at&t website for support/tutorials. It is: https://www.wireless.att.com/support/ This should take you to the correct arera. You need to make sure that your checking info for a V3 razr, go to PHONE/DEVICE SUPPORT and then click on TUTORIALS. This should take you to where you need. If the phone showing is not a v3 you need to change it to a v3 by clicking on the (not my phone/device? link located under the cell phone picture.). Under SELECT CATEGORY you need to go to TEXT MESSAGING-SMS, under the SELECT TUTORIAL click on SEND/RECEIVE TEXT MESSAGE. This will give you the information you need to hopefully fix your wifes phone so that she can use Multi-Media. Unfortunately when a phone is unlocked it won't always work for Multi-Media. For example: if the phone was initially a T-Mobile phone the settings for Multi-Media will not be set up for AT&T. They are different. I hope I have helped you.
Jul 22, 2008 | Motorola Mobility RAZR V3
Nokia 6131 - Memory card/camera
you have to try to format your memory card, but dont forget to backup your files before formating it. good lack
Jun 25, 2008 | Nokia 6131 Cellular Phone
Trouble downloading pics
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 14, 2007 | Canon PowerShot A70 Digital Camera
Card not initialized
when you goto format, make sure you click over to okay because ifyou dont then your just clicking cancel over and over
Apr 29, 2006 | Fuji FinePix E510 Digital Camera
Palm Treo 650 Handheld Logo
218 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
