Question about GE JBS55 Electric Kitchen Range
Glass on door broke. Is it easy to replace?
  • GE Master
  • 43,501 Answers
Most of the time the replacement is really not that hard...here is a tip that I wrote about that...
Range/Stove/ Oven Door Glass Replacement
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
The very bottom link on this tip will help you with getting the part online...
heatman101
Posted on May 11, 2010
Toyota avalon drivers side power window broke
glass broke, lot of parts in electric windows to break.
glass.
remove door car.
remove glass holding bracket
remove glass.
its far more complex but
you can read on ALLdata.com
or the FSM.
its all there, read it.
lots of steps. and pitfalls.
on some cars upper door seals need go come out.
Dec 27, 2013 | 2005 Toyota Avalon
The glass broke need to replace it.
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
heatman101
Feb 03, 2011 | GE Spectra JBP78 Electric Kitchen Range
The glass outer glass on my oven window broke can it be repaired? It's a Thermador Model# CT227NPRS Serial# 98020093
heatman101
Jan 05, 2011 | Ovens
Good day friends regards before that quite I they want to inform that I have a general kitchen electric spectra modelo:n º-J BP65WOCIWW and it has serial:n º-MZ227832Q IS OF WHITE COLOR step an...
I have replaced glass in many ovens. It is fairly easy. You set the new glass into the bottom piece then screw in the handle and top piece, then the sides snap in place. the door can be removed from the stove for easy repair. Simply tip the door to the broil position and yank it off the hinges. sit it on a work surface and be sure to add the insulation. very important!
Aug 21, 2009 | General Electric JBP65MMBS Range
Broke Glass door for Jenn-Air 701642K
Hi, Go to www.bellparts.com and tyoe in the model # located on a tag either around the door opening or around the bottom drawer.
I hope this helps you.
Vic
Jul 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Can't replace outer glass on oven door.
Go to (www.searspartsdirect.com). Enter your model number and select (door) under (browse subcomponents) You can view the door assembly parts. Hope this helps
Mar 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Door Face needed (Glass broke, model discontinued, can't get part)
Linda, if you can't find a replacement door at local used appliance repair shops - check the Yellow Pages - look to see how the door comes apart.  It is probably held together with 6 or 8 Philips screws.  Get the door apart and take out the broken glass.  Call around to see if an appliance repair store has an oven they are discarding that has the same size glass or larger.  If the glass is too big, phone a few glass shops to see if they can 'cut' it down for you.  Some tempered glasses can be cut and sanded down to the precise size you need. Take your old broken glass to the shop to be used as a template. You should be able to get away with this type of repair for $50 if you compare prices. Cheers, Pavel
Oct 21, 2008 | Amana AOCS3040 Electric Single Oven
Inside oven door glass broken
I have a Kitchenaide Gas Range. KGST307 Inside glass on the oven door broke.. need to replace. is it easy to do? going to order glass online.. I did call some local repair people.. looking at a $200.00 to $250.00 bill to fix... NOWAY............ I can buy the glass and do it myself... Need some help if it can be done..... Any Help is COOL!! Thanks TED... 425-549-0150 WA. 98014
Aug 19, 2008 | KitchenAid KGST307 Gas Kitchen Range
Top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
GE JBS55 Electric Kitchen Range Logo
130 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
