Question about Reliance Controls 60-100 Amp Utility Subpanel for up to 15,000-Watt Generat
In a box of 10 electrical parts, 2 are defective. If two parts are randomly chosen from the box, without replacement, what is the probability that both are defective?
  • 843 Answers
2/90
Posted on May 11, 2010
A BOX OF 7 GLAVES CONTAIN TWO LEFT-HANDED GLOVES AND FIVE RIGHT-HANDED GLOVES
First one, chance is 5/7
Second one, 4/6
So odds of 2 RH in succession is 5/7 x 4/6 = 20/42 or 10/21
Mar 22, 2013 | Prentice Hall Basic Business Statistics...
After going over 40mph the check engine light goes on n it gives the code 440
How did you read that code on your car? A 92 Accord is supposed to give you pre-OBD honda codes, which are all below 100. Please check the code again and re-post it.
Jan 04, 2011 | 1992 Honda Accord
Egr excessive flow fault P0402 on 2001 Ford escape causing random misfire/ rough engine at any random speeds/idle. Replaced EGR Valve, selenoid and DEFP or whatever its called along with a new catalist. ...
Easy fix! I've had the same problem/headache and spent the same on parts. Replace your back-pressure sensor (it's easy to do-about $38-at Autozone or others) They can also show you where it is and how to do it. For a 2001 Taurus- part looks like a black box with 2 vacuum hose nipple holes and an electrical connection. It's definitely not your egr valve (costly!) I Should've asked my fleet service at work first rather than after. This repair consist of undoing 2 little vacuum hoses and an electrical connection clip and replace with new part in reverse order-DONE! Autozone will erase the codes with scan tool and your on your way. Ten thousand miles later and still no issues with mine! Good luck!
Sep 25, 2009 | EGR Cycling
Electric egnitor for a gas dryer lights but does not stay on
Check the following-
Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 03, 2009 | GE Dryers
Mazda Tribute 2002 engine cuts out randomly
I had a Mazda 626 with a similar problem, the car seemed to 'shut down' with no warning, even at highway speeds, as if I just turned the ignition key to 'Off'; After trying to fix it unsuccessfully by replacing several electrical parts, the problem was found to be a defective ignition switch, it was replaced and the problem went away.
Apr 29, 2009 | 2005 Mazda Tribute
Want to replace the "guts" of a G.E. load center in small box
You won't find any "guts", like longer busbars, to upgrade. The panels pre-date most of the codes and you will not find replacement parts, except maybe a breaker or two. For panels that old you are looking at the possibility of having aluminum wiring and/or two conductor wiring (hot and neutral). In either case, your local code office or utility company will probably require you to update to current requirements. You cannot connect aluminum to copper without nickel connectors because of galvanic corrosion, and if you are disturbing any of the wiring you will probably need to upgrade to three conductor (hot, neutral, and ground). You should be able to buy "Square D" HOM series replacement panels with breakers for about $120 or less.
--Peter Nomikos, ICC Master Code Professional
Building and Zoning Director, City of Mauldin, SC
Feb 24, 2009 | Gb Electrical 100 Amp GE Load Center
Reliance Controls 60-100 Amp Utility Subpanel for up to 15,000-Watt Generat Logo
590 people viewed this question
Top Reliance Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Reliance Hammering Expert? Answer questions, earn points and help others
