Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
The dishwasher runs for 1 1/2 hours on the wash cycle.
The dishwasher is new and seems to cycle through the wash cycle repeatedly. The setting on the dishwasher is normal.
    President:
  • 949 Answers
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
Posted on May 11, 2010
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
NEW DISHWASHER REPEATS THE WASH CYCLE FOR OVER AN HOUR 7 HALF
Dear Customer
please perform the follownig checks
please rate this,thank u.
Dec 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch sgi45e12gb/22 dishwasher won't stop
hey you..I have a whirlpool dishwasher too that would not
stop the wash cycle...it would run for 2-3 hours,
and then run thru the whole wash cycle again!
so..I had a whirlpool factory trained repair man come to
the home. He ran a diagnostic and it was 100% good,
so he called Whirlpool headquarters spoke to them;
said...........every 250 hours the dishwasher will
RE-CALIBRATE itself! running for 4-4 1/2 hours
straight, in order to re-calibrate itself. I was
interupting this by opening the door before it had
run the full 4 -41/2 hours of it's self-maintenance program.
Perhaps that your dishwasher is doing too?
p.s. always make sure you get a repairman that
is factory trained in your specific brand, otherwise
you'll waste $$$ money with a repairman who doesn't
have access to the corporate tech's and direct access
to their parts/inventory.
good luck with your dishwasher!
mine is the whisper quiet with computer control on front
of the door.
Apr 11, 2008 | Dishwashers
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Too long for a cycle
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... ) You answer will allow us to direct you the solution. Good luck !
Jun 27, 2006 | Zanussi 24 in. DE6744S Free-standing...
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
341 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
