Question about Toshiba 26LV610U LCD TV
In my televition,one paart of the screen is
In my televition,one part of the screen is displayed.the other half remains pink...can u say how to fix the problem?
  • Toshiba Master
  • 12,061 Answers
Www.pdfee.com/.../Toshiba%20rear%20projection%20training%20manual - United States
www.scribd.com/doc/.../Toshiba-TV-LCD-Training-32wl36p
www.scribd.com/.../Toshiba-CN27E90-TV-Technical-Training-Manual
Ok these service manual, and training manual, will assist you in troubleshooting and possible repair. It seems that one of your "Boards" will need to be replaced, use these manuals to sort your problem out.
Posted on May 11, 2010
My dell e6400 is flickering rapidly that you cant read anything as from when you turn it on.
Sounds like a damaged display or GPU. Try an external display to confirm either way.
Jun 02, 2016 | Dell LATITUDE Computers & Internet
Why are there black vertical lines on the right half of the picture?
Vertical lines indicate a bad screen not the T con board. Only fix is to replace the screen.
Nov 15, 2015 | Samsung 65" Series 6 LED HDTV - UN65F6400
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
Screen split in half horizontally and duplicated
You didn't supply the make , model of laptop or the OS you are using? Has there been any damage? Dropped? Open Control Panel, Display adapter, Uninstall the Graphics adapter, reboot. Allow the Windows OS to apply the generic driver. post results with info.
Jan 27, 2013 | Computers & Internet
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
Laptop display only displaying the top half of the screen
Test it with an external monitor if it works fine then you will need to replace your LCD screen.
May 04, 2010 | Dell Latitude D600 Notebook
EXACTLY the same problem.
This is a common lcd issue. The pcb board in the lcd is defective (cracked or broken). The only way to fix it is to have the lcd replaced
Jul 10, 2009 | Toshiba Satellite P105-S6177 Notebook
Colorful spot on screen and line running up from it.
hi,
if the line and spot is coming on the bios mode of pc(check in bios mode how is the display?) this is the issue with screen.
Jun 02, 2009 | Computers & Internet
Konica minolta magicolor 5430 DL
pleas make color calibration from printer quality menu and try again
Apr 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Toshiba 26LV610U LCD TV Logo
354 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
