Question about Toshiba Satellite P205D-S8804 Laptop
No power what so ever toshiba satellite p205-s8804
I was disassembling my lap top and powered it down. I accidently. Turned it on and I was takeing the batteryout at the same time. I broke it down to about half way and cleaned it reassembled it and now there is no peer what so ever. If I plug in my ac it just flicks once. The battery will not do anything and neither will the ac cord. Does anyone know what to do with this hunk of junk now
I have the same hunk of junk with the same problem. Totally dead. I replaces the battery and the charger is fine. HELP!!!
Posted on Jan 16, 2013
SOURCE: Toshiba Satellite L25-S119 Does not Power on
The Toshiba laptops are famous for the power jack wriggling loose from the motherboard. Once it gets so loose the adapter power stops and it uses battery power until that runs out. You can usually move the power cord around until it starts working again but this is just a temporary fix and the jack will eventually need to be replaced. Most computer shops charge between 100-250 bucks for this service.
Posted on Jul 17, 2008
Benimur
  • 6966 Answers
SOURCE: Toshiba Satellite M45 Power Problem
Your concern (auto shutting down) with Toshiba could be caused by excessive power drain by some of the attached devices such as the WiFi, LAN among others. On the other hand, it could also indicate that the battery is already weak and constantly requires charging and at times eats up most of the power from the adapter leaving nothing for the motherboard to use. In some repairs I have done, switching off / or removing entirely unneeded devices correct the problem. In some instances, auto shut down is caused by dirty/clogged airducts/heatsink of the processor, failing blower/fan and/or poor ventilation.
Of course, it could not be ruled out that internal problem with the power supply/regulator to have caused the shut down. Alternately, there are some viruses and malwares that could trigger shutdowns.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
  • 502 Answers
SOURCE: Toshiba L300 satellite --- Power cord does not connect!
Unplug the powercord and try to move around the DC-Jack with a small flatheat screwdriver. If the jack moves around freely or the middle pin has too much slack you most likely have a defective DC-Jack. You can replace it yourself there are guides online that show you how to do this. The repair takes about 2-3 hours. I work for a company called Laptop Repair NYC and we do this repair frequently.
Posted on May 20, 2009
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
SOURCE: Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Posted on Jul 04, 2010
Toshiba satellite p205-s6267 backlight
Your system is consuming much power.
Go to Control Panel, Power Options.
Click "Advanced Power Settings" for your current power plan.
Under the section "What happens when I close the lid", choose "Do nothing" for both "Battery" and "Plugged-in".
Click "Apply" and "Ok".
Now, close the lid of your laptop and open it, it would restore but next time don't overload your system power.
This is common with Dell and Toshiba.
Apr 03, 2010 | Toshiba Satellite P205-S7402 Notebook
Toshiba satellite P205-S6287 the power button
Make sure the battery has a full charge, and that it's plugged into a wall socket, then try the power button. You will get the same symptoms as a bad power switch if your battery power is very low. Other than that, the battery could be bad, or going bad. If the problem is a faulty power switch, you will have to have it replaced.
Mar 12, 2010 | Toshiba Satellite P205-S6287 Notebook PC
I want istall window Xp in my liptop tosiba P205-s7476
make sure the lap top can support win xp home or office and then locate a disc and install but must have key
Jan 06, 2010 | Toshiba Satellite P205-S7476 Notebook
Had laptop sitting in lap and turned body briefly lap top went off and will not power up. the fan runs but will not power up. screen is blank
you may have hit the sleep or standby button. Try turning the pc off by holding down the power button untill you hear the fans stop. then power up as usual.
Nov 08, 2009 | Toshiba Satellite M35X-S111 Notebook
No sound device is installed in this computer you cann't make a call above problem in my lap top satellite. how to solve it
please post your laptop model number and OS, could be a case of sound driver not installed. If your laptop is a Toshiba, you may download drivers from: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 25, 2009 | Toshiba Satellite P205-S7402 Notebook
Troubleshooting Toshiba Satellite P205-S6267
is the laptop getting extremely hot on the bottom.
Could be thermal shut down (keeps the cpu from meltdown temperatures)
Robert
Aug 18, 2008 | Toshiba Satellite P205-S6287 Notebook PC
All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Jul 22, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba p205-s6237
Hi
I would boot into Safe Mode and run this utility to check your registry and startup.
http://www.download.com/Startup-Inspector-for-Windows/3000-2086_4-10291346.html?cdlPid=10452094
OR
You can try the original OS cd and repair the installation of the OS.
Last Resort
If that does not work then see if you can roll your computer back to a date prior to the problem starting.
/SPH
May 19, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite P205D-S8804 Laptop Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
