Question about Epic T 40 Treadmill
Jazfit Treadmill not working
My Jazfit treadmill comes up with EO on the screen when I turn it on and doesn't do anything else. How do I get it to work?
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
maxtreadmill
  • 832 Answers
SOURCE: When I turn on the treadmill, the incline is stuck
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
  1. If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
  2. If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
  3. If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced
Posted on May 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill is plugged, lights are on but does not work
The standard calibration procedure to calibrate an Icon treadmill is done by holding down the speed up and stop keys while inserting the safety key or putting the key in place (if magnetic). If your keypad is not responding, because your treadmill keypad has failed or the console computer has failed. In these cases, the keypad can be replaced in limited instances or the console has to be replaced.
Now if you are able to get in calibration mode then Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, This means that it passes the EPROM test. If it shows ff or 2f your upper console will need to be replace.
Next step if eprom passes: Press either incline key and the incline will calibrate automatically.
DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). if you get the the number to 85 and the belt does not move , on the lower board you will see a like flicker that would be the speed control this tells you that the upper console and terminal cable is good ,but lower board defective.
Posted on May 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill turns on but belt not turn on
Press the Stop and the Speed Up keys down while inserting the safety key this will get the into calibration mode. The next step is to press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. if it says 2F, FF or Fail then the upper console needs to be replaced
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window
If the belt does not move in this mode then the controller board is defective and needs be replace.
Posted on Jun 01, 2010
I have a Jazfit 5333 treadmill - the speed and time are not working - led is fine but does not show time or speed just random numbers flash...how do I fix this??
Sounds llike you may have problem with your speed control module which will also be linked to yr time display . Call a treadmill tech for quote & availability of parts cost labour & service
Mar 02, 2015 | Exercise & Fitness
Jazfit top 49 treadmill
Are you sure its E S and not E 5
Dec 16, 2013 | Exercise & Fitness
Jazfit txo
see the video and proceed according. Lube the rollers bearing front+back with silicon or wax( depend of your mark, model) read your owner manual.
God bless you
Oct 18, 2013 | Icon Epic T60 Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Jazfit T38R Incline up button beeps but doesn't do anything.
Dear Sir:
1(any signal from the console which could be a damaged cable 2(or the console itself has failed. 3(motor control board may have failed from a worn treadmill belt and deck 4( the motor may have burnt out. 5(potentiometer geared to the motor so the console knows what height the incline is at.6( gearing can slip, giving the console.
RUN THE software calibration for Help and trouble
see my personal TIPS for HELP
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
New fitness treadmill TS01 that reads EO how do i reset it
What do you do when EO shows up on your treadmill. We have tried to put the safety switch back and also replug the treadmill into AC power directly as suggested in the manual but it hasnt solved the problem.
Jan 16, 2011 | Exercise & Fitness
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Your Problem: jazfit-750 Treadmill motor will not turn on
DEAR
AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good
Mar 18, 2017 | Exercise & Fitness
Epic T 40 Treadmill Logo
111 people viewed this question
Top Epic Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
