Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG dishwasher LD-12AW2 shows fault of AE when part way through cycle
  • 351 Answers
SOURCE: HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Posted on Mar 03, 2008
SOURCE: ie problem on lg dishwasher
I have cleaned the screan and tested the valve and no hose is kinked. Prolem still exists.
Posted on Mar 09, 2008
  • 210 Answers
The IE is telling you it is not getting enough water. Could be your water pressure is low. Check to make sure the there is not a build up of grime, or calcium deposits in the water hose, and at the valve.
The other thing is if your unit is an older one, prior to mar 07, you may have broken wires in the door. Remove the door panel and look for any wires that are stuck in the insulation. The sensor wires are thin and gray in colour. Splice the wires and put some of the white insulation in between the wires and the door so it cannot happen again.
Broken wires can be hard to find if the break is not all the way through.
Sgt Lauder
Posted on Jun 02, 2008
onthejob5130
  • 640 Answers
SOURCE: LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Posted on Feb 04, 2009
  • 423 Answers
SOURCE: My LG dishwasher, model LD-12AW2 runs for 10 - 15
Happy to be of some help. Please keep this list around so you can take notes if the problem comes back.
Good Luck!
Posted on May 14, 2009
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
My LG dishwasher, model LD-12AW2 runs for 10 - 15 mintues and then goes into a H and flashing 'E' fault. This fault isn't listed in the manual.
Good Luck!
Apr 13, 2009 | LG Dishwashers
1 F in dispaly window
well,i have the same problem.the solenoid doesn't open for the water to flow in.... but still working on the problem....
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
179 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
