Question about Samsung S760 Digital Camera
Dead battery caused lense to stay out
The batteries died with the lense still out, now with new batteries it wont come on and the lense wont go back in?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 11, 2010
2004 polaris ranger battery not staying charged when operating but when engine is off battery not affected cutting out and dying what could be the problem?
battery is being drained as it operates and not taking charge
check tightness and clean both terminals and cables
how old is the battery
may have a dead cell ..wont take charge
check the charging input to the battery with a volt meter
has to be above 12 volts
if lower or equal to 12 volts ...no good
the charging stator inside the engine needs testing or repair or replace
stator is another word for an alternator or a generator
why it plays up
best guess the ATV if a 12 volts system wont run on 11 volts
Oct 13, 2016 | ATVs
Why wont truck stay running.
Check the alternator! It may be bad!
May 15, 2014 | 2005 Ford F-150 SuperCab
I get no response when I turn the key in the ignition switch. If I turn the key in the switch there is nothing
two things would cause this a totally dead battery. or a loss of the ground. headlights are grounded to the body and run directly off of the battery. since your lights dont work this would point to a dead battery.to find out if the battery is bad or if it was caused by the charging system not working. try jumping the car if you can get it started here are a couple of simple ways to check the charging. one with the car running remove the possitive cable from the battery if the car dies the altanator is not charging replace it. if the car stays running the battery most likely has dead cells and wont hold the charge. the other way is to take a bolt or small ferous metal object and on the back of the altanator there is a round cap in the center of the case if the piece of metal your using will stick to that cap then the altanator is producing a charge and the battery is the problem. if no magnetic field is present then the alternator is bad and needs replaced
Aug 29, 2010 | Toyota 4Runner Cars & Trucks
WHEN TURNING KEY IT WONT START LIKE A DEAD BATTERY JUMP IT, BUT STILL WONT START.
if it doesnt even click over straight nothing at all ....
battery is no go at all
1.if it starts off a jump.....
altinater could be bad...take positive battery terminal off battery while car is on ...if it stays running its good if car dies altinaters bad.
2.if its good replace battery with brand new one....
3.if the cars battery is brand new and car acts like it wants to start real bad but wont...
if you have gas in the vehicle and it sounds like it dont ... your ecm is bad electronic control module or ICM ignition control module.....its the brain the spark
Jan 14, 2010 | 2002 Chrysler Sebring
The battery on my 89 ninja 750 wont stay charged
i would first try a new battery if that don't work the magneto may be bad the battery if it has a dead cell could short the magneto
Sep 04, 2009 | 1989 kawasaki ZXR 750
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
Xxzz - doesn't retract doesn't turn on
Try this, it may or may not work. Also please post a comment on the blog on whether it worked or not:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Sep 26, 2007 | Canon PowerShot A80 Digital Camera
Samsung S760 Digital Camera Logo
103 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
