Question about Samsung SMT-170 PROFESSIONAL 17" TFT-LCD MONITOR
Power light is blinking but no display on SMT-170 MONITOR OR SECURITY SYSTEM. SYSTEM DUAL QUAD SOQ-080N
    Genius:
  • 1,354 Answers
U have problem with Display from the Coputer not from the Moniter
try to run from baios mode
and re setupp your display
Posted on May 11, 2010
Smt 190 dx won't turn on after power outage
Processor could have some garbage in it to to the power surge and if you unplug the set from the wall for 40Min., it will rest back to normal.
Feb 11, 2011 | Samsung SMT-190 19" Flat Panel TFT LCD...
Samsung SMT-190Dx DVR monitor won't turn on after power outage
There is a fuse on the Power Supply Board replace that. Hope this helps
I have a Samsung SMT-190 19" FLAT PANEL monitor and the picture won't show but a few minutes and then a sound comes on and the power light is blinking and the picture goes out and leaves only the blank...
More then likey yuor Inverior Board is going bad if not that, Its the Power Board
First check Invertor This Happens a lot Its hard to find someone to fix it.
Well I had a hard time. I just waited and bought one for parts and fixed it Myself
Good luck
PS. You can still use it just get a different Monitor. The Video out on the Samsung to the
Video in on a different Monitor IT WILL WORK
Jul 13, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
Samsung digital quad soq-080n security system, no display, only blinking light. Suspect unit in power saving mode.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 03, 2010 | Samsung SMT-170 PROFESSIONAL 17" TFT-LCD...
How do I reset a SMT-190DN samsung security system to factory default ....I lost the password...
Just talked to Samsung regarding Reset procedure. Simple: Press CH2 and Alarm buttons on receiver at same time for 10 seconds. It will reset to factory.
Oct 06, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
Forgot password to Samsung SMT-190DN
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
all settings will return to the default values.
• Press the POWER button.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
NEED DEFAULT PASSWORD FOR SMT-190DN SYSTEM BY SAMSUNG. CAN'T SHUT RECORD OFF
unplug the computer and plug it back in.
try password factory setting password 4321.
make sure you push the "STOP" button on your remote first
Feb 27, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
Samsung SMT-170 PROFESSIONAL 17" TFT-LCD MONITOR Logo
415 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
