Question about Dell Dimension 4600 PC Desktop
Program will not recognize DVD
I have a Dell Inspiron 4600 with two drives. Drive E is a Sony DVD RW DW- Q120A and Drive D is a TEAC DVD+RW DV-W58E drives. Under normal conditions they both perform well. However, when attempting to burn a downloaded movie from utorrent that has been formatted using avi2dvd the E drive is ejected with the instructions to place a DVD into the drive, although there is one (DVD-RW) 4.7gb already there. When I attempt to use the D drive, I get the message "no disk in drive" even though there is one in that drive.
Any ideas toward this solution??
  • Harold Estep Mar 28, 2008
    Will kiss the ground you walk on if this works.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    UTorrent? Did you check that file for virus contamination, by chance?
    New Friend:
  • 136 Answers
Start the program and then insert the disk so it can read it right on time
Posted on Mar 28, 2008
I have an external teac dv-28e-n usb DVD writer device which does not recognise and burn DVD rewritablce discs.
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
Dec 20, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
THe DVD/CD writer all of a sudden does not write to a dvd, although a few months ago it did just fine. I have a teac dvd+rw dv-w58e in a Dell 4600. I have unistalled and reinstalled it. I have restored...
Not to over simplify your problem, but have you cleaned the optical eye of the drive lately? Sometimes we overlook the simple things.
The laser optical eye is located at the bottom of the drive. This equals a good(?) area for the eye to become covered with dust.
Some use a drive cleaner that resembles a CD disk with a brush on it, and a cleaning solution.
I use a can of compressed air for computers, and shoot air towards the bottom of the drive.
(Drive tray open, computer off, AND unplugged from power)
Installed and uninstalled it? Through Device Manager? This never works for me.
Neither does roll back the driver.
I use a different software method, and then a physical one if that does not work. Past this point the drive is unusable, and has seen the end of it's Life Cycle.
(Computer mechanical hardware components have a Life Cycle. So many hours of usage)
Software Method:
1) Start>Right-click on My Computer>Left-click on Properties>
Left-click on Hardware tab>Device Manager
2) Left-click on the + sign next to DVD/CD-ROM drives
3) Right-click on the drive name in question.
(Teac w58e)
4) Left-click on Properties in the drop down menu
5) Left-click on the Driver tab
6) Left-click on Uninstall
There will be a warning window.
'Warning you are about to uninstall this device...and so on'
Click on OK.
7) Close the Device Manager window. Close the System Properties window.
8) Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Wait 1 minute. Turn the computer back on. After Windows has fully loaded, you should see out of your task bar,
'Found New Hardware',
and perhaps, 'Found Teac w58e'
See if the optical drive works now.
No?
Shut the computer down normally. Unplug from power. Open the computer case.
TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
Unplug the power cable, and the interface cable from the drive. (Data cable)
Press the Power On button in, and hold it in for a count of Five seconds. Let go of the button.
Do this procedure two more times.
Now plug the power cable, and the interface cable back into the Teac optical drive.
Close the computer case. Plug the computer back into power.
WAIT 1 minute.
Turn the computer on.
If this doesn't do it, I suggest the Teac optical drive is toast.
Jan 14, 2010 | Dell Dimension 4600 PC Desktop
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
Jan 14, 2010 | Teac CD-Rewritable W58E CD-RW Burner
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
Apr 23, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
DVD-RW not recognising blank disk
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
160 people viewed this question
Alun Cox
