Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Sears DYT 4000 24 intek twin, not getting gas in carb..pull off gas line just before carb crank have gas, pull bowl off bottom of carb & crank no gas..
4 Suggested Answers
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
  • 201 Answers
SOURCE: Hello, I have a craftsman dyt 4000 with the Briggs
remove fuel bowl and check needle valve and float assembly
Posted on May 08, 2009
  • 86 Answers
SOURCE: Carftsman DYT 4000 42" 18.5 OHV Intek Plus Fuel Problem
Sounds like you have a float problem their is a needle and seat the lets gas into bowl of carburetor if its bad it will not stop letting fuel in the carburetor causing your problem (Be sure to change oil before ing engine over or you could damage engine (with this problem you get gas into case which will remove oil from engine parts inside !
Posted on May 09, 2009
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a Craftsman 23 hp Twin OHV Intek engine garden tractor. It has recently started idling badly, the motor runs up and down up and down. Battery, fuel filter, oil and oil filter, are newly changed,...
Before you get more into that engine I would suggest trying new gas especially if its been sitting for a while. Then I would try running some carb cleaner through it and see if that settles things down. If there is any water in the fuel it can cause those type of issues so try the simple fixes first then if all else fails go to the harder fixes.
Jun 19, 2011 | Briggs & Stratton Briggs Stratton Intek V...
MY BRIGGS &STATTON 18.5HP STARTS BUT PULSAITING REAL BAD, THEN JUST DIES, OR IT WILL START RUN GOOD MOW GOOD ONLY 10 MIN THEN JUST DIES!! AFYER SITTING A FEW MINS. IT WILL GET ME BACK TO THE GARAGE ...
you need to service your carb. it has a bowl on the bottom of the carb. it should have a screw or a nut holding the bowl in place some of the new ones have a spring clip. anyhow take it loose and there is some holes in the bolt that need to be cleaned out if tou dont have anything small enough homedepot and lowes sell a tip cleaning kit for cutting torches and it has some tiny wies that will work . some carbs have a screw in the middle of the hole after you take off the bolt look in the center and if it looks like a flat head brass screw then you can un screw that peice to and clean it thos tiny holes get cloged real fast get som carb cleaner and clean everything and the bowl it only takes gas 30 days to oxyzadize and it will leave behind a yellow scale like plaque on your teeth and will foul up the whole thing . keep note when removing the bowl one side is lower so keep it the same direction when removing it will allow the float to settle down right to allow the gas to flow into the bowl. the float has a little valve that has a rubber tip on it and it can get stuck and not work right if things seem clean and still runs funny get a carb kit from truvalue o a lawn epair shop get all info off side of motor . when installing bowl if you have a screw with a spring out the bottom of bowl screw all the way inn then turn back out 2 1/2 turns to adjust proper flow if screw is on side of carb turn same amount if too much gas is idling rough turn screw in some hope this helps
Apr 10, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My 6.5 HP B+G lawn mower has gradually required more priming to start and now will not continue to run without constant priming. I have sisassembled the housing and found that the two screws that hold the...
remove the sediment bowl on the bottom of the carb and see how much dirt/contaminent is in the bowl,then lift the float (the metal or plastic round donut shaped object in the bowl) and see if gas runs out,if not then the carb is plugged and engine wont get gas to operate,then you need to try carb cleaner or a complete carb rebuild
Apr 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My Sears riding mower chokes itself out after warmed up,
Careful with the high octane.. That can burn a hole in the piston..
It might be fludding.. At the bottom of the carb should be a bowl.. One bolt at the bottom.. Take it off and clean it.. Spray some carb cleaner up in there where the float is..
If that dont do it --
Maybe the float is bad & taking in fluid..
If it has sat for long piriods of time - the carb might need to be cleaned & rebuilt..
When gass sits in there for a long time it shalacks and wont work correctly..
Pop off the carb & take to your local small eng shop. Shouldnt cost to much..
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
May 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
My briggs & stratton will not start
If the engine fires on starting fluid, then you are missing fuel, so you need to start with the source, is fuel getting to the carb? if not why not. Check fuel lines, shut off valves and filters.
If it is, is the carb float allowing the bowl to fill?
If there is fuel in th float bowl, then you need to look at mixture and idle settings.
hope this is of some help.
Ed
Apr 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
140 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
