Question about Whirlpool Calypso GVW9959K Top Load Washer
My washer is plugged in and I checked the breaker switches. The dryer comes on just fine but the washer does not (when I push a cycle and start - NOTHING - no sound of any kind). Has been working fine. What is the problem?
  • Whirlpool Master
  • 8,220 Answers
Line filter probably blown pictured on page 37. Troubleshooting starts on page 43 and suggests you check for a blown line filter. So what is a line filter and what is its function and why did it blow? A line filter sometimes called a transorber is a fusable link that keeps radio wave signals from spiking delicate electronic controls when water valves are turned on and off. Probably blew from sudsing conditions too much soap wrong soap etc. or a voltage spike of some sort. Electrical storm stuff like that.
Posted on May 11, 2010
My maytag epic z washer will not start a cycle.
may have blown a fuse check in the panel and also check to see if it has a thermal fuse included, I would also check the door switch as it can cut off all power also
Feb 19, 2015 | Maytag Atlantis MAV6000 Top Load Washer
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Oct 01, 2010 | Frigidaire Electric Dryer
Dryer won't start in Frigidaire FGX831CS0 stackable. Assumed it was a bad start switch because honey bunny had broken the knob off and was using a pliers to start it but have replaced that and still nada,...
Check the door switch. Turn on dryer as you push in on switch where the door catch is and see if it starts . when closed the pin may not be pushing it in.
Mike
Jun 05, 2017 | Frigidaire FGX831CS Top Load Stacked...
My dryer (frigidaire stackable washer/dryer) just stopped working, the washer is fine, but when I start the dryer nothing happens. I set the time and push the button and NOTHING.
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Dec 09, 2009 | Frigidaire Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Dryer will not turn on
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
189 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
