Question about Dishwashers
Leaking from the base during washing cycle - have checked hoses water not leaking from these
Wataer does not come on even though it is not turned off. Purchased Apr. 02. Serial No. FM1533599, mocel 15872
Posted on Feb 15, 2013
  • 12,061 Answers
Http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
Top link, is for a troubleshooting guide, below that is a service manual, use this to troubleshoot and hopefully repair.
Posted on May 11, 2010
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
My whirlpool top load washer is leaking out the front side, no hoses are leaking.
Hello there:
Your washer can develop several types of leaks. I will post this solution in 2 seperate posts for you ok?
You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
May 26, 2010 | Whirlpool Washing Machines
Machine is leaking water from somewhere?
there is a seal between the drum and transmission,more than likely thats where its leaking. also check your fill hoses and valve
Jan 09, 2010 | Kenmore 22422 Top Load Washer
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Washing machine is leaking water.
During fill only
All the time
During fill only
All the time
Nov 18, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Dishwashers Logo
138 people viewed this question
Top Dishwashers Experts
