Question about Canon PowerShot A70 Digital Camera
Dropped my digital camera in pool I let it dry overnight replaced battery and nothing happened what else can I do
  • Canon Master
  • 12,061 Answers
I am sorry but once any electronic equipment and water intermix, there is an immediate irreversible chemical reaction, at circuit board level. and this renders the unit totally unrecoverable, in any normal sense, you see current goes through the water to places it never usually would. No amount of drying out or anything can fix it, as I related, there is an instant reaction, especially if ON at the time of immersion, that totally ruins the unit.
Posted on May 11, 2010
How do i fix my phone dropped my phone in water
Dry your phone with simple towel. Then put your phone in a bag of rice for over 24 hours. Take out your phone and try to start it and see if it works. I am talking about phones in which battery can't be separated. If you could separate the battery then, dry it from outside then pull out the battery and dry gently inside then put it in a bag of rice overnight and start it next day.
Jul 07, 2014 | Sony Cyber-Shot DSC-W570 Digital Camera
Our Kodak easyshare z710 got water on it. Any hope for it working again? Have tried drying it out overnight but nothing happens so far.
Here's a last chance option:
Take as much of the device apart as possible: remove battery, memory cards, lenses. Bury the device in a bowl of rice and leave overnight. Cross your fingers.
Hope it works!
Mar 04, 2011 | Kodak EasyShare Z710 Digital Camera
Goo day! my canon IXUS 90 IS drop at the swimming pool i tried to dry the cam with a towel my friends told me to dry it with a hair blower as soon as i got home i tried to blow dry the cam...the next dya...
Wait ,Wait ,didn't you romove the Canon digital ixus 50 battery at once when the camera drop at the swimming pool. You'd better ask the CANON Service Centerto for help,this will completely good and safe for your Canon IXUS 90, wish you good luck!
Dec 14, 2010 | Canon IXUS 90 Digital Camera
Won't power up
Have you tried cleaning the battery contacts inside the camera? The problem that you describe is frequently due to a corrosion buildup that prevents the full power of the batteries from flowing to the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cleaning clears the problem about 90% of the time, and I hope it works for you.
Sep 16, 2009 | Olympus Camedia C-725 Digital Camera
Camera fell into pool; was retrieved in 3 sec.doesn't work
You said, "Camera fell into pool; was retrieved in 3..." But you failed to specify if 3 is seconds or minutes or hours. If 3 is seconds, i.e. you retrieved the camera in 3 seconds, then you should be in luck. The first thing you should have done is pull out the battery/batteries. This is to ensure that there will be no leakages of electric current across the electronic components. This is what actually will destroy the camera. Once the batteries are out, the camera needs to be dried. But to be sure that the camera dries well it needs to be opened up. This is the only way you can be sure that there isn’t still some water lurking in a tiny space/corner somewhere inside the camera. What this means is you need to take it a proper technician. Your dealer should be able to provide one. However if 3 is in minutes then you may not be in much luck but you should still take it for repair for a proper assessment.
Sep 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
My camera got wet i tried to dry it out with blowdrier it still wont work
First of all, you never want to try to dry out an electronic device with a blow dryer. Hopefully you did not apply enough heat to damage any of the sensitive parts. You also never want to try to turn on an electronic device that has gotten wet. You should remove the battery immediately and dry off any water on the exterior of the device. Place the device in a bowl of rice for 24-48 hours. Many times this will pull out the moisture. I dropped my cell phone in the pool last week and it certainly saved me. You can also use Damp Rid or Silica gel if you happen to have them.
Jul 04, 2009 | Canon PowerShot S2 IS Digital Camera
Dropped my camera in a pool of water in a glacier 12 months ago. I immediately took out the battery and memory card. I then spent 2 hours with a hair dryer drying the camera. Since then the camera has...
There is no relation between the two incidents that you explained. The recent problem might have occurred due to damaging of the lens. MY solution is to replace the objective lens ( lens assembly) and the motor ( if needed ). If it costs much, then go for a new one, since digital camera with high pixels rates are available cheaply now a days.
Mar 30, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Dropped Ixus 50 in water...!
It may recover afeter drying. However, tap water is full of stuff thats not going to play nice. You are better off gettting a gallon of Distilled water. this is electrically non-conductive and leaves no residue when dried. take out the batts and flash memory and soak the thing for a few seconds. hopefully the tap water and drink have not fully dried and you may get some use back out of it. You need warm heat to dry it out, Place it near a heating vent, heater or other heat source. you can get it as hot as you stand to touch (they are good to about 120 degrees). and a fan for circulation may also help. keep drying for at least a day, even a sunlit spot indoors can help
If water entered the lens group or got on the sensor, you are not likely to be able to repair this camera. repair costs will likely exceed its replacement cost.
Good Luck
Jan 09, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Dropped camera in pool
If it does not fire up, I would dunk it again - this time in warmed, distilled water, moving it around a bit, then putting it in a warm (not hot) place to dry but I would probably give it a week.
Distilled water is non-conductive whereas pool water is . . . who knows?
Jul 10, 2008 | Canon PowerShot A520 Digital Camera
Open camera and place in a bag of rice for a couple of days to absorb moisture.It's worked before on cell phones.
Jun 30, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
125 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
