Question about Soltek SL-865PRO2-FGR Motherboard
Blue screen I bought a soltek Motherboard back in 2005. Ive put together the parts and now encounter a problem when i instal the OS - XPsp2. Also when it starts, it shows that bios is not installed. During installation of this OS, it would go past formating and when im at about 60% of copying the files, a blue screen would appera with the mesage STOP: 0x000000D1 (0x82BF3BBC,0X0000002,0X0000000,0XF83D0EB1) at times F83D0EB1 base at F83CA000, DateStamp 3b7d83e5ha. I have tried changing dates to 2005. Memory installed is 512mb Please help. I donot know if my video card could be causing the probles as it is nt onboard. Lesh IRQL-NOT-LESS-OR-EQUAL
  • badman92 May 11, 2010
    how can i save all passwords on my computer
    Genius:
  • 1,019 Answers
you should setup the motherboard with the current Date/time not 2005 set to 2008.
It may also be worth looking at the motherboards site, for an updated bios.
If you feel that your video card is causing the problem, go into the bios setup screen F2 Or delete on bootup. view the configuration settings for the video card, see if it,s set to launch pci or agp initially. set to the card you have installed on the computer. AGP is usually a single slot card oin the motherboard. PCIs can have 2-6 White Slots on the motherboard.
If you need any more advice, just Ask.
Mike @ Compurepair.
Posted on Mar 29, 2008
SOURCE:
I cannot install OS winxp onto sata drive pc is Acer aspire x3200
There could be two reasons for the blue screen either a bad harddrive or loose memory cards in the slots. Try reseating the memory cards on the motherboard.
Also please post back the Stop code you are getting on the blue screen
Thanks for using Fixya
proton
Jul 27, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
Blue screen, error, non-sence while installing os
You have "bad" RAM in your computer, which is causing those "symptoms". Replace the RAM.
May 22, 2009 | ASUS Motherboard, nVidia 750i, Core 2...
Desert Combat 9.0 Map Dosen't Load
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alklkl3
Apr 25, 2009 | Abit IC7 Motherboard
Blue error screen when starting up computer
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Aug 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
IAN ????????
I only work with a AGP 4X graphics card.
If you want to sell that motherboard im intressted. Mess me please
Jul 04, 2008 | Soltek SL-85DRC Motherboard
Two long beeps and no booting. Motherboard Soltek SL-75FRN2-L. The computer has worked with this motherboard for about 3 years. The problem started like that: first problems with the hard disk with the...
You could try re-seating your ram and your video card if applicable.
2 beeps generally upon post depending on the bios is video or unstable ram.
Depending on how many sticks you have on the board try re-seating them if that doesn't work diagnose the faulty stick by putting them in 1 at a time.
Hope this helps
Jan 19, 2008 | Soltek SL-75FRN2-L Motherboard
System booth
the ram memory might not be compatible from your motherboard, you should have find it on the list of your motherboard manual. the manual have the list of memory cards' qualified brand. likewise, try to install this to ther slot if the problem still occurs then you may return to your vendor and inform them about the specs and kind of your motherboard and the problem you are encountering so that they will give you the right memory card to use. you can also ugrade your bios thru the internet so that you don't need to return this item.
Dec 13, 2007 | EliteGroup 755-A (ECS 755-A) Motherboard
Instaling soltek sl-kt400-c
Oops you could have blown the board. do you have the origional mother board book that came with the board first day. If so check your wiring.
Dec 09, 2007 | Computers & Internet
Soltek SL-865PRO2-FGR Motherboard Logo
111 people viewed this question
Top Soltek Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Paul Bade
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
