Question about Texas Instruments TI-89 Calculator
I keep trying to do a 2-proportion Z test in my calculator (by going into stats, test, 2-prop Z test) and i enter all the info (correctly) and it comes out with error; Domain. what am i doing wrong?
  • kakima May 11, 2010
    First, could you clarify the calculator you're using? From your description, it doesn't sound like at TI-89 but rather a TI-83/84.
    Second, it seems as if you're not entering correct info. Why don't you post at least one set of data that leads to the domain error?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Jun 15, 2010
Stats 2 prop z test
n1 and n2 are integers. The proportions p1 and p2 must satisfy the conditions of the Hypothesis you are testing. p1 not equal to p2, p1 < p2, p1>p2.
Dec 10, 2013 | Texas Instruments TI-89 Calculator
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
Can you please help me on how to calculate mean, median, mode, standard deviation calculation on casio fx-991ms scientific calculator
This will show you how to do statistics (calculate average, standard deviation, regressions etc.) as to the mode and median refer to the definitions.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Apr 19, 2011 | Casio FX-115ES Scientific Calculator
I don't know anything about physics or statistics or anything like that so I cannot do a test problem. :-( But I am in physics now and the professor said we needed a calculator that can do 1 and 2 variable...
Do not go buy another calculator because this one does 1-var, 2-var, as well as some regression models, and some distributions.
For 1-var and 2-var statistics read on.
Jan 22, 2011 | Casio FX-115ES Scientific Calculator
How can i find the standard deviation and the Q1 and Q3 of data, please write in all the steps...thanks
TO FIND THE Q1 and Q3. The calculator does not calculate them (I swear I had nothing to do with it). You can use the définitions you have to calculate them.
Mar 03, 2010 | Casio fx-300ES Calculator
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
Graph function is giving an error
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
May 14, 2009 | Texas Instruments TI-83 Plus Calculator
When i try to graph a scatter plot on my ti-83 plus it says ERR:INVALID DIM or it gives me a blank graph, how do i graph it?
May 12, 2009 | Texas Instruments TI-83 Plus Silver...
TI 84 Silver Plus
I'm not sure, but it probably gives the error because one of the values you entered isn't valid. It's too big or too small.
For more information, look here:
http://tibasicdev.wikidot.com/2-propzint
If this doesn't solve the problem, please let me know.
Gr Marijn
Nov 24, 2007 | Texas Instruments TI-84 Plus Calculator
Standard deviation
Here goes if you still need this...
STAT, EDIT, put information into L1 if only one variable stats, but put info into L1 and L2 if it is frequency table stats.
Then choose Stat, over to CALC, 1, enter...if 1 variable stats then press enter again. If frequency table stats, then choose STAT, over to CALC, 1, 2nd, 1 [L!], 2nd, 2 [L2], enter.
Oct 15, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-89 Calculator Logo
755 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
