I have a Sony TC 630 Reel to Reel Stereo Tapecorder..Pinch Wheel is sticking and will only move when forced and brushes as well...Any help ?
    Problem Solver:
  • 9 Answers
Sounds to me like your Sony has a common problem among vintage reel tape decks..dried /frozen grease/ and or a lack of lubrication. carefully apply a tiny bit of fine lube oil, like 3in1, on the swing mechanism that carries the pinch roller...(you may have to remove the front metal deck face to fully access the swinging pinch roller mechanism) ) . do NOT get any oil on the rubber pinch roller..(best to make sure after by scrubbing the pinch roller surface with a cotton swab lightly dipped in non chemical household cleaner, like 409, or awesome orange i get at the dollar store. Then use the dry end of the swab to ensure the pinch roller is dry. .The pressure pads should swing upward and press the tape against the heads when in play/record mode..if they do not swing up, they are binding/ or out of adjustment....they are spring loaded so when the reel deck is in the stop position the spring loaded pressure pads are held down...play/record mode releases them to freely swing up and press on the tape against the heads.
Posted on Jun 08, 2010
Where can I find an owner's manual for Sony TC-355 tape recorder
Hi Cloise,
Go to HIFI engine at this link. Sony TC 355 Manual Stereo Tapecorder HiFi Engine .
Here is the TC355 page. Sony TC 355 Manual Stereo Tapecorder HiFi Engine
You must create an ID and Login to obtain the free download.
Fare. Well.
Dec 12, 2014 | Sony Audio Players & Recorders
How do you rethread a TC-730 reel to reel tape?
It goes down under the tension arm and between capstan and Pinch roller under next tension arm and into the reel.
Jun 11, 2014 | Sony Audio Players & Recorders
Sony Stereo Tapecorder TC-355
Contact Sony they will tell you where the nearest service center is there.
Jan 28, 2014 | Sony Audio Players & Recorders
My sony tapecorder tc-330 vu meter shows only one side working with the needle fluctuating, what causes that?
I have had that in a TC-366, the diode and a capacitor were the reason but you will need Technician tools, meters ans a soldering station to get the unit fixed. Sometimes the meter movement gets
knocked out due to abuse or shock. Does it move at any time as when you turn on the deck?
Sep 07, 2012 | Audio Players & Recorders
I have a sony stereo tapecorder model # tc-330 , and need a parts and service maual for it. Does anyone have one I could buy?
I don't have that one but if you are looking for a good pare manual then stereomanuals.com will result in the best one to get.
Sep 05, 2012 | Sony Audio Players & Recorders
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
Sony TC-255 reel to reel Tape won't turn
you need to have a tape in place on the reals or it will stop.Hold the tape feeler spring in place and prevent it from moving forward it is located on the left side just remove the SONY stereo tapecoder cover and you see it
May 27, 2009 | Sony Audio Players & Recorders
Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Sep 24, 2007 | Audio Players & Recorders
702 people viewed this question
 Grubhead
Grubhead
