TV Hatachi 50UX22BA turns off after about ten to thirty seconds after turning it on. Could it be the on/off push switch P/N FE00062R
  • 5,138 Answers
Go to Encompass Parts Distribution and Look up Model number .
Posted on May 11, 2010
Changing battery positive pole sparked . Engine starts but it immediately gets off. Still have the lock symbol on the dash .
That was a reset, try a relearn. You'll need a charger on the battery. Ten minutes on, thirty seconds off. Do this three times, then try to start. If that doesn't work, then it has to go on a scanner to see what happened. Sparks like yours usually don't hurt anything. But they can spike and burn a computer. Next time put the positive side on first.
Dec 30, 2015 | 2013 Chevrolet Tahoe
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
How to rempve a kill switch on a 2009 chevy impala
Sorry, you can't. If it has just lost memory, you can reset it. Turn the key one for ten minutes, off for thirty seconds. It's reset, if you don't have other problems, like wires broken. Then it needs put on a scanner to see what's wrong.
May 17, 2015 | Cars & Trucks
Mi car turn off suddenly
Turn the key on(don't try to start) let it set for ten minutes, Turn it off for thirty seconds. Then try to start. Security is set.
Mar 19, 2014 | 2000 Pontiac Sunfire
How to reset my security or antithef ligth on escalade 2004 wont start or cranck
Try this it works on an 2002 with the master key take and turn the key on wait about ten minutes the antitheft light will go off then switch the key to the off position wait 5 seconds and turn back to the on position do this 3 times total. On the 3rd time switch the key off then start the vehichle. It may take a few trys of reprograming to get it to work it takes about thirty minutes to do.
Oct 08, 2013 | Cars & Trucks
IT TAKES A while to have screen on theTV
If I understand your (very brief) problem correctly, the problem is that when you turn on your TV or DVD player, it takes a while to show anything. If the time is less than a minute for a dvd player, or less than ten seconds for turning the TV on itself, then this actually isn't a problem. Modern TVs and various other tech often take several seconds to turn on, and that may be the only 'problem' you're experiencing. It's an unfortunate fact of modern life. Things take a little while to start up sometimes. If the time for the TV is in excess of about thirty seconds, or the time for a DVD/Bluray/whatever player is more than five minutes... Well, then it could be a problem, but I'm afraid I'd need more information than you've provided.
Oct 08, 2012 | Televison & Video
Changed battery and replaced lost key. Now it won't start
nitabelle57, It sounds like your security system will not recognize the new key you purchased. Keys have a chip in them which has to be recognized by the security system in order to work. The new key has to be programmed by your security system before it will start your vehicle. You will need a battery charger to program the key as this procedure takes thirty minutes to do. Put the charger on the battery. Be sure everything else is turned off. Place the new key in the ignition and turn it to the run position. The security light should come on. After ten minutes the security light should be out, if not proceed anyway. Turn the key to the off position but do not remove it. Wait five seconds and turn it to the run position once again. Wait another ten minutes and turn it off again. Wait five seconds and turn it to the run position once again. After the final ten minutes turn the key off (do not remove it) Wait thirty seconds and then the key should be programmed. If you have any other keys they will not work now as the security system is now programmed for the one key. If you have another key and need it for another driver then start the vehicle with the newly programmed key and let it run for about a minute. Place the extra key in the ignition and turn it to the run position and wait sixty seconds. This should solve that problem. Good luck with this.
Aug 10, 2011 | 1997 Pontiac Grand Prix
I turned on the dryer and it ran for about thirty seconds before it just stopped. I pushed the start button again, but it wouldn't start at all.
Is the motor trying to start? Is there power to its outlet?If it is gas try plugging something else into the outlet to check for power. If it is electric turn the breaker off for ten minutes then turn breaker back on again and try the machine. If you have a volt meter you could check the outlet for power that way. If the motor is running when you push start but the drum isn't turning than you probably have a broken belt. Is the door all the way shut? If so you could have a broken switch at the door. To check the switch would require opening the machine case and using an ohm meter to check the switch. The last thing it might be is the timer. If it is an older (ten or more) unit and it is the timer then it might make more dollars and sense to get a new machine.
Oct 07, 2010 | Roper Dryers
Tv is on every thirty seconds it will turn off for thirty seconds light begins to blink and then it comes back on by itself. the tv does this of and on every thirty seconds
"LAMP"LED light indication blink?The projection lamp has not been change in this tv like a 1 1/2 or 2 years?Tv on and used like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 11, 2010 | Sony Televison & Video
TV Hatachi 50UX22BA turns off after about ten to 30 seconds after
No, Replace both of your STK ICs STK392-110s use 150s Mats has them 1-800-628-1118
May 11, 2010 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
