Question about Homelite Factory Reconditioned 26cc Gas-Powered MightyLite Hedge Trimmer
How do i replace the pull cord on the ht-22 homelite gas hedge trimmer.I can not find the manual on line.......
  • 333 Answers
Remove the housing with the coil in it. Remove the screw on it, its the screw with about 3/8 washer on it. It is where the old rope was hooked up, and should still have a piece of it under the washer. It has a D shaped groove under it. take the new rope and burn the frays on it make it stiff and small. Turn the pulley around and around until it gets real tight, and align the hole in the pulley with the hole in the shroud. Take a c clamp or visegrips and clamp it in place if you can. I just hold it, then feed the rope through the hole in the shroud and pulley and rap it round D shape groove. Replace the screw and washer. Tighten it up then let go of pulley. It should zip up real quick and all way to the handle, and be real tight.
Posted on May 11, 2010
Fuel Ratio What is the fuel Ratio for the Homelite HT -17 Hedge trimmer?
2 stroke tools generally run at 50:1
100ml of oil in 5L of petrol
Oct 29, 2015 | Homelite Garden
How do i start my homelite ht -17 hedge trimmer
it sounds like your throttle cable is to long i have the same problem with mine... when starting up pull the throttle full on with your finger whilst you have it set on choke. best to do this on a very flat surface.
Nov 03, 2010 | Homelite Expand-It Hedge Trimmer...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Change cutting line
Pop of bottom cover and wrap new line by turning head or replace with different spool or blade cutter
Jul 01, 2009 | Craftsman 22" Gas Hedge Trimmer
My Homelite 26 HT Hedge Trimmer is stubborn to start and then only runs on Full Choke at full throttle, but not smoothly. Whats up with this?
Jets in carb are dirty. Take carb off and clean, blow out all jets, you may have to use thin wire to get all gunk out. Also fuel line might be dry rotted. Put carb back on and adjust settings on carb.
Jun 18, 2009 | Garden
Will not start
did you try the air filter. could be not getting air. And are you sure it is firing. if so try a spray of ether. You can but at auto parts store. but be careful with it. don't use much. If it is firing it will go.
Jun 06, 2009 | Craftsman 22" Gas Hedge Trimmer
Homelite Factory Reconditioned  26cc Gas-Powered MightyLite Hedge Trimmer  Logo
393 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
