Question about Hitachi Televison & Video
TV Hatachi 50UX22BA turns off sfter about ten to
TV Hatachi 50UX22BA turns off after about ten to thirty seconds after turning it on. Could it be the on/off push switch P/N FE00062R
  • Hitachi Master
  • 12,061 Answers
No it is unlikely that it is ever the actual switch, it is more probable that the switchmode power supply, has shut down the set for safety reasons, so as to avoid a fire and explosion or both. This is a classic symptom of such an event, and I see similar sets frequently in my shop. Unfortunately, WHY, this is occurring, is what must be isolated and repaired, often the faulty component has been damaged by the "Cause" which gives us a symptom, and just treating the symptom, while possibly appearing to remedy the situation, simply fails again, as the "Cause" was not attended to. Follow the troubleshooting procedures and the manual will soon zero you in on the faulty, board/component. Then use the manual to obtain your part number and you may indeed be able to source your requirements, eBay, and the 'net are a wide source for parts.
http://www.givemefile.net/smanuals/tv/hitachi/file/35358.html
http://www.retrevo.com/support/Hitachi-50UX18B-TVs-manual/id/371bh851/t/2/
To assist you I have provided a service manual, and a user manual, between these to you should be able to isolate and hopefully repair your set.
Posted on May 21, 2010
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: TV Hatachi 50UX22BA turns off after about ten to 30 seconds after
No, Replace both of your STK ICs STK392-110s use 150s Mats has them 1-800-628-1118
Posted on May 11, 2010
Changing battery positive pole sparked . Engine starts but it immediately gets off. Still have the lock symbol on the dash .
That was a reset, try a relearn. You'll need a charger on the battery. Ten minutes on, thirty seconds off. Do this three times, then try to start. If that doesn't work, then it has to go on a scanner to see what happened. Sparks like yours usually don't hurt anything. But they can spike and burn a computer. Next time put the positive side on first.
Dec 30, 2015 | 2013 Chevrolet Tahoe
Reset/disable anti theft 2002 Chevy cacavalier
Reset is turn the key on for ten minutes, turn it of for thirty seconds, try to start. Relearn is three times this, try to start after the third time.
Oct 31, 2014 | 2002 Chevrolet Cavalier
Mi car turn off suddenly
Turn the key on(don't try to start) let it set for ten minutes, Turn it off for thirty seconds. Then try to start. Security is set.
Mar 19, 2014 | 2000 Pontiac Sunfire
IT TAKES A while to have screen on theTV
If I understand your (very brief) problem correctly, the problem is that when you turn on your TV or DVD player, it takes a while to show anything. If the time is less than a minute for a dvd player, or less than ten seconds for turning the TV on itself, then this actually isn't a problem. Modern TVs and various other tech often take several seconds to turn on, and that may be the only 'problem' you're experiencing. It's an unfortunate fact of modern life. Things take a little while to start up sometimes. If the time for the TV is in excess of about thirty seconds, or the time for a DVD/Bluray/whatever player is more than five minutes... Well, then it could be a problem, but I'm afraid I'd need more information than you've provided.
Oct 08, 2012 | Televison & Video
Changed battery and replaced lost key. Now it won't start
nitabelle57, It sounds like your security system will not recognize the new key you purchased. Keys have a chip in them which has to be recognized by the security system in order to work. The new key has to be programmed by your security system before it will start your vehicle. You will need a battery charger to program the key as this procedure takes thirty minutes to do. Put the charger on the battery. Be sure everything else is turned off. Place the new key in the ignition and turn it to the run position. The security light should come on. After ten minutes the security light should be out, if not proceed anyway. Turn the key to the off position but do not remove it. Wait five seconds and turn it to the run position once again. Wait another ten minutes and turn it off again. Wait five seconds and turn it to the run position once again. After the final ten minutes turn the key off (do not remove it) Wait thirty seconds and then the key should be programmed. If you have any other keys they will not work now as the security system is now programmed for the one key. If you have another key and need it for another driver then start the vehicle with the newly programmed key and let it run for about a minute. Place the extra key in the ignition and turn it to the run position and wait sixty seconds. This should solve that problem. Good luck with this.
Aug 10, 2011 | 1997 Pontiac Grand Prix
Tv is on every thirty seconds it will turn off for thirty seconds light begins to blink and then it comes back on by itself. the tv does this of and on every thirty seconds
"LAMP"LED light indication blink?The projection lamp has not been change in this tv like a 1 1/2 or 2 years?Tv on and used like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 11, 2010 | Sony Televison & Video
May 11, 2010 | Televison & Video
After 1 minute delay, turns on screen covered with colored spe
I just turn off the TV set, wait 30 seconds, then tun it on again and the
specks are gone/
Dec 13, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
TV turns off on its own
Set may have poor/cold solder connections on power supply board and convergence board.
Dec 17, 2008 | Mitsubishi VS-55707 TV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
